CVD Pin Clips
General info, Q&A.
TViz
CVD Pin Clips
Post by TViz »
Hello everyone,
Can someone please send me the post or tower link for the CVD pin rings? I swear, if I lose another pin holding together the CVD, I'm going to go insane. :evil:
I have two different CVD's. The b44's for my "old is new" RC10 and MIP GT CVD's for my RC10 Graphite Monster Truck Conversion.
Thank you!
steve
Re: CVD Pin Clips
Post by steve »
heat shrink tub or a vary small drop of red thread lock on the ring. hit it with a hot sodering iron to get it off. most glues do not hold up well to heat , about 200 f glues will soffen and the bond can be broken
TViz
Re: CVD Pin Clips
Post by TViz »
Thanks Steve. Haven't tried the heat shrink tubing/thread lock but have tried a ton of electrical tape and believe it or not, the pin is still popping through it.
There were these metal rings that I saw once in a post on here but haven't been able to find them since. I think I will continue to search for those but in the meantime, go with your reco.
Anyone else having the same issue?
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Re: CVD Pin Clips
Post by Lonestar »
nope - here's what it looks like with shrink wrap on my CE
the b4.1 uses some cool retainers around the pin... part#7996
but the truth is, if you degrease all the parts properly, machine a flat spot on the pin, use quality threadlock on the grub screw, and a good quality wrench to tighten the crap out of it, they pins should NOT go out.
Paul
tim.sanderson
Re: CVD Pin Clips
Post by tim.sanderson »
steve wrote:heat shrink tub...
+1 on the heat shrink. I put a little bit A.E. diff grease in the joint, then shrink tube over top. Works like a charm.
TViz
Re: CVD Pin Clips
Post by TViz »
Thanks for all the great feedback. I found the clips as well and ordered a bunch.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNZA6&P=7
steve
Re: CVD Pin Clips
Post by steve »
I looked at my b44 and the ring had tunded so the in could slide out. The grub screw was tight , never had the cross pin on other cvd slip befor. thinking more about it stopping the ring from rotating is key, as a last resort after the ring is on and clean use green locktight , small drop and the capalary action will pull it around to much and it will be glued tight. use heat to get the ring off. lonestar has great tip as well
Jay Dub
Re: CVD Pin Clips
Post by Jay Dub »
I just found this thread, and I would like to know your process for building your CVD's. I have been using CVD'S in my cars for as long as they have been available. And I have never once had one come loose. On-road, Off-road. I have just never had it happen. Just wondering if you are missing something. -Jeff
Lonestar
Re: CVD Pin Clips
Post by Lonestar »
Jay Dub wrote: Just wondering if you are missing something. -Jeff
My bet is, a proper wrench and some motor cleaner ;)
Paul
