Triumph Tranny Questions
- losiXXXman
- Been thanked: 5 times
Does the Triumph diff use the same components as the Ultima/Optima Option House Diff (obviously excepting the belt pulley)?
In other words, If i source the internal pulleys, case and motor plate - am I good to go??
Oh, and some kind of 5mm topshaft/slipper assembly...
Thanks!!
Thanks!!
- Bormac
- Has thanked: 20 times
- Been thanked: 11 times
- losiXXXman
Re: Triumph Tranny Questions
Really
. I looked at the manuals online, and you are right, the diff assy looks different, the hubs have separate rings on the Triumph. But the outdrives look the same, the bearing size is the same, it may be worth trying. I'm trying to find a fairly cheap way to upgrade my Ultima with a better tranny. It's insane trying to find spur clusters for this thing, and I still cannot seem to pick up a gear cover either.
- highwayracer
- Been thanked: 6 times
hello,
the ball diff for the ultima (with the exception of the diff gear) is identical to the one used on the triumph. All of the early ball diffs were the same.
Regards,
highwayracer
Regards,
highwayracer
Triumph gear cover? http://cgi.ebay.com/Kyosho-TM-9-Triumph-2WD-Buggy-Gear-Cover-Set-/290418130810?pt=UK_ToysGames_RadioControlled_JN&hash=item439e44ff7a
Try these Guys might be able to help you I see they have my bevel gear I been looking for.
http://www.happyhobby.com/hobb_html/kyosho.htm
- losiXXXman
USA1 - the Ultima gear cover is the one I cannot seem to get a hold of. Also spur clusters are trouble too. It is for these and other reasons (slipper clutch, 48p (metric)) that I'm exploring the Triumph tranny as an upgrade for my Ultima. It's a pretty common mod, for those running an Ultima...
- Diggley
losiXXXman wrote:USA1 - the Ultima gear cover is the one I cannot seem to get a hold of. Also spur clusters are trouble too. It is for these and other reasons (slipper clutch, 48p (metric)) that I'm exploring the Triumph tranny as an upgrade for my Ultima. It's a pretty common mod, for those running an Ultima...
Pretty easy too...adapting a standard 48p gear is a simple mod if you don't mind living without a slipper clutch.
Projects and shelfers:
- highwayracer
On my first triumph, I was using a robinson spur (standard) and the traxxas slipper pegs. The rest of the triumph slipper components were used. The only thing I had to fabricate was a bushing with a 4mm inside diameter but with a 3/8 outside diameter for the spur.
- 582 Views
Last post by JPAE07
- 852 Views
- 1136 Views
Last post by highwayracer
- 1703 Views
Last post by Mr. ED
- 42 Replies
- 8969 Views
Last post by hugger19
- 31 Replies
- 3563 Views
Last post by USA-1
- 760 Views
- 666 Views
Last post by aconsola
