Lubricating the stealth?
susko
Post by susko »
I am in the process of rebuilding my stealth and was curious about the lubricants used. I know the thrust bearings are supposed to have the black grease and the stealth diff lube on the diff. I know the top shaft, idler, and outer diff gear are not supposed to be lubricated but I have heard that the black grease makes the gears last longer and run smoother. I also found that the trans had been lubed with black grease in the past (it has all been cleaned off now). Any thoughts?
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Re: Lubricating the stealth?
Post by klavy69 »
you pretty much had it up to the last part with the black grease on the gears. No need. They are self lubricating. If anything I would think it would harm/slow down your tranny...
susko
Post by susko »
thanks
I had just read on some other forums that black grease or Tamiya's ceramic grease might help to preserve the gears. I think that manufacturer specifications are probably best.
Lowgear
Has thanked: 121 times
Been thanked: 796 times
Post by Lowgear »
Users browsing this forum: No User AvatarSemrush [Bot] and 10 guests
