so i just had to have.
i allways wanted one but i also said i would stay electric but ill have to try it out it was pretty cheap.
here it is.
looks like its missing a fuel line it has one short one
I believe the one way bearing is housed inside the nut within the pull-start housing(unless that's just the O.S. version). I may be wrong(and I usually amklavy69 wrote:thumber pretty much summed it up. Only problem with his starting 'tool' is that you still need an operational one way bearing for it to work![]()
I guess we won't know until he pulls down 'er skirt and shows us the goodies...klavy69 wrote:you might be right
