yokomo yz10 94 wheel hub part numbers
Hoping someone might be able to help!!
I have a yokomo yz10 94 and I want to check I have the correct hubs on the car (front and rear) are these part numbers correct? and which are the front and which are the rear
ZD433 - Yokomo Wheel Hub Set 3.5mm ARE THESE THE FRONTS??
ZD434 - Yokomo Wheel Hub Set 4mm
ZD435 - Yokomo Wheel Hub 5mm
ZD436 - Yokomo Wheel Hub 6mm ARE THESE THE REARS??
Thanks in advance
Scott
Thanks in advance
Scott
Re: yokomo yz10 94 wheel hub part numbers
sorry, forgot to say I want them with 4 holes not 2 are the part numbers I given correct for this model???
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
You can have a look here: http://www.rc10talk.com/viewtopic.php?f=7&t=3801
But I already did and the answer is not really there as the manual itself doesn't refer to these part numbers directly but rather to bag numbers. That being said, the Japanese list at the end of the manual refers to all the re numbers you mention above. I will measure them on mine tonight if somebody hasn't replied in the meantime. Too bad Hyeong translation of the parts list is gone...
Come and visit the stable
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
Other than measuring mine on the car I'm not sure, the rears on your 94' are the 870 type for sure. Yokomo part numbers rarely changed per model change, but I think the offset that your needing didn't come around until 93' and I think that they all have 4 holes at that point.
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
I have the 94 YZ-10 catalog and these numbers are listed:
ZD-434 4mm with description and small illustration
ZD-436 6mm with description and small illustration
also listed are :
ZD-433 3.5mm with description and no illustration
ZD-435 5mm with description and no illustration.
You can draw your own conclusion as they don't state which is standard but I think the ZD-434 and ZD-436 shown with illustration would be the standard that is supplied with the kit and the others are options.
also listed are :
This is all very interesting!
Thank you a01butal
ZD-434 & ZD-436 is what I thought! Ive placed an order, Thanks for your help guys. These ol yokomo's are a nightmare for finding parts!!!!
- Been thanked: 5 times
Where did you order from??? I have a yz10 missing front right suspension and need parts - Any assistance is appreciatedCATS wrote:Thank you a01butal
Tell me about it
lee
- 2361 Views
Last post by Mr. ED
- 289 Views
Last post by AscotConversion
- 2354 Views
Last post by aip47-2008
- 56 Replies
- 9180 Views
- 1255 Views
Last post by rccars4sal
- 1316 Views
Last post by bully
- 584 Views
Last post by bscotti
- 992 Views
Last post by LTO_Dave
