RC-10B3 slipper questions
General info, Q&A.
EvolutionRevolution
Has thanked: 17 times
Been thanked: 34 times
Post by EvolutionRevolution »
First, what is the diameter of the layshaft?
Second, on the inner slipper hub, if you lay the slipper hub on your workbench with the part that holds the pin pointing up, how high is that most narrow part of the slipper hub?
Third, what length of the layshaft is needed to mount the slipper?
Re: RC-10B3 slipper questions
I can only tell you that the shaft where the rear plate locates on the pin drive is 3/16" diameter. It necks down through the slipper area. Don't have one handy to get the other measurements.
If the thunder tiger cars use a similar slipper, I have read that it's transmissions use metric bearings, that top shaft may be 4mm, but may also be 5mm. you would have to check the manual and bearing kit to know for sure.
are you wanting to use the b3 slipper assembly on something other than an associated vehicle?
oh my god..... i almost had a heart attack. you gotta be careful, you can't just link me to the kyosho forum without any warning. i need to be prepared. :shock:
:wink: :mrgreen: :lol:
crap, sorry buddy.....I'll have to be sure to put in a disclaimer next time :mrgreen:
"NSFS" = not safe for scr8p
:P :lol:
EvolutionRevolution
Don't worry, the slipper will be protected from the Kyosho by mounting it on another manufacturer's layshaft :lol: - right now HPI, unless I find a better fitting one.
