Part number help
Part number help
Hey fella's
I need help with either finding a part or a replacement.
I want to put the stock RC10 shocks on my restores and when I took apart the shocks some of the nylon washers that sit behind the C clip were bent or trashed.
Anyone know the part number for them? A compatible replacement?
I've searched for them but I haven't come up with anything.
I bought the shock rebuild kit but they are not in there either.
Thanks
Tom
Thanks
Tom
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
Re: Part number help
For the bottom load gold shocks you can borrow the plastic washers (and retaining clips) from this Traxxas rebuild kit:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJJ17&P=ML
Then use the AE rebuild kit for the rest of the shock.
4187 or 6466 of these should work. 4187 are 1/8 id .030 thick nylon washers. 6466 is a kit different thickness washers. take a look on RC10.com web site for those part numbers.
Thanks guys.
The one from the Traxxas kit looks promising.
I'll look up the others. I have about 8-10 sets of shocks to rebuild.
I went and looked at these today at lunch.MIKE VALENTINE wrote:4187 or 6466 of these should work. 4187 are 1/8 id .030 thick nylon washers. 6466 is a kit different thickness washers. take a look on RC10.com web site for those part numbers.
The 4187 is smaller than the one I need I am pretty sure. 6466 is the plastic spacer set that goes on the inner shaft of the shock.
I'll have to keep looking I think or take a look at the Traxxas kit.
Yeah I'll check them out.
I didn't have the number at the time and this particular shop is set up for online sales so it's just a huge space with lots of drawers of parts. I'd still be there.
- 1287 Views
- 588 Views
Last post by a01butal
- 1513 Views
Last post by liquorboxracing
- 697 Views
Last post by PBR Allstar
- 769 Views
Last post by Dual
- 926 Views
Last post by aip47-2008
- 994 Views
Last post by clm
- 896 Views
Last post by kink
