Chassis prep ~ powdercoat
- Has thanked: 14 times
- Been thanked: 60 times
Quick question for you guys,
I'm gathering up a bunch of parts to build an OIN runner and I'm going to have the aluminum parts powdercoated. Do I need to strip the ano off the parts before the powdercoat is laid down? Should I use oven cleaner or sandblast them? If sandblast, do I need to protect the threaded screw holes in some way?
Thanks
Thanks
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
Re: Chassis prep ~ powdercoat
I wouldn't powder coat the shocks, you might have tolerance issues. It will also fill the threads and shrink the holes in the chassis that will will have to re tap. Best thing would be oven cleaner (it must include a diluted amount of caustic soda to work) or simply use diluted caustic soda (quite messy an dangerous stuff) but I'm not sure about the dilution proportion. Sand blasting sounds ok as well. Why not ano it? It's more resistant, lighter and looks better IMO. Of course you have less colours to choose from...
Come and visit the stable
Yeah, I was just planning on doing the nose plate, the chassis, and the motor plate.
I was thinking, if I sandblast it, I could thread some old screws into the holes to protect the threads?
- MotoObscura
- Has thanked: 45 times
- Been thanked: 65 times
It's ok to powder coat over anodizing, in fact I've heard that it is a recommended base surface for aluminum parts.
Nick DiVitto
My current vintage racing lineup: Associated RC10 B2, RC10 Team Car, Losi XXT, RC10T, XX4, XFactory X5, Schumacher CAT 2000
www.moto-obscura.com
My Youtube Channel
- LTO_Dave
- Has thanked: 52 times
- Been thanked: 287 times
orangemazda wrote:Yeah, I was just planning on doing the nose plate, the chassis, and the motor plate.
I have a bunch of old screws set aside just for this purpose. Unless the powdercoater knows enough to use silicone plugs or screws to fill the holes, you'll have to re-tap them once it's finished.
I've powdered over anodizing with no problems, but I usually sandblast RC10 tubs/noses/motor plates just to have a rough surface for the powder to stick to. You may also have to run a countersink bit in the chassis holes for the screws to sit flush, depending on how many coats and the thickness of the powder.
- 1311 Views
Last post by RC10th
- 521 Views
Last post by THUNDERSTRIKE1
- 1674 Views
Last post by uzzi
- 873 Views
Last post by kenooze
- 1245 Views
Last post by Kyoshojoe
- 3156 Views
Last post by juicedcoupe
- 753 Views
Last post by 1300GT
- 1450 Views
Last post by Mad Racer
