KYOSHO drive washers
bully
Been thanked: 6 times
Post by bully »
Hey everyone I bought a lazer zx ages ago and finally got around to going thru it when I noticed it has 3 drive washers of one size and one that is different thickness altogether.. I noticed the part number is OT-19 which are the aluminum alloy ones and I also saw kyosho #92636 which is advertised as the steel version of the OT-19... So for occasional use which ones should I purchase and do the steel ones last longer? Anyone had experience with these your opinion is appreciated... By the way the re released scorpion's look awesome..
j0pp3
Re: KYOSHO drive washers
Post by j0pp3 »
I prefer the alloy OT-19 because they deform a tad bit and makes a good bond against the wheel axles. Especially when I use expensive universals in front I prefer sacrificing the hexes in the long run.
Cheers
Joel
bully
Post by bully »
Sounds like a plan mate thanks, you are right about the expensive universal's....
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarAmazon [Bot], User avatarSwath and 4 guests
