Removing gold anodizing from shocks
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Post by Asso_man! »
To strip off without any danger a pair of rear gold anodized shocks that were quite worn, I decided to use the manual sandblasting technique like proposed in another post. It took me some time but if you don't have to strip the shock caps like me, an hour for two shocks must do.
The worn gold shock before being sandblasted with a 600 grade sandpaper:
Come and visit the stable
Asso_man!
Post by Asso_man! »
before and after sandpapering two times, firstly with 600 grade designed for 1:1 car bodies, secondly with a 3M 150 (thin) sandpaper, then polishing them with a liquid metal polishing product from HG ( http://www.hginternational.com/ ). I'm definitely quite happy with the result and as I'm a little bit lazy, I decided not to strip the bottom and the top end collar, wich is fine...
Asso_man!
Post by Asso_man! »
The differnece between a polished shock and unpolished one, striking :!:
Asso_man!
Post by Asso_man! »
The two rear shocks are now ready to be installed on the A&L chassis...
Asso_man!
Post by Asso_man! »
Asso_man!
Post by Asso_man! »
a bottom view 8)
Asso_man!
Post by Asso_man! »
Asso_man!
Post by Asso_man! »
The completed chassis with truck front gold shocks that are too good to be stripped... they'll remain like that maybe until I find a worse pair... time will tell... The wing is only there for show :wink:
shodog
Been thanked: 91 times
Post by shodog »
Those look pretty good. were you going for that matt finish or a high shine. You could easily get those to look like chrome.
Asso_man!
Post by Asso_man! »
I like them already like that, but I could always polish them more...
those shocks have a cool machined look to them. i think i'd leave them like that.
Asso_man!
Post by Asso_man! »
thanks Scr8p, they will only be polished once in a while to keep on blinging, but it seems I have a new disorder, I also stripped the nose plate, which was in a poor state already, now aluminium front A-arms could still add something though 8)
