ID these rear arms, carriers from RPM
teshreve
Has thanked: 31 times
Been thanked: 27 times
Post by teshreve »
Losi JRX Pro-SE?
If so, they would only work using the rear holes on the chassis (lengthening the wheelbase) as the lower shock mounts are very forward.
Bought my first RC10 in 1989
teshreve
Re: ID these rear arms, carriers from RPM
Post by teshreve »
I guess I should only have made 1 thread. I'll add anything else here
How about some help with these shock towers. Don't fit anything I have (I think)
Check the arms for marking, they may say 'rpm truck' on them. If so they are truck arms for losi
teshreve
Post by teshreve »
No markings other than RPM.
I just put them on a Pro-SE and they are are a perfect fit for inner hinge pin, length, and shock mount position in 2 axis. And it sure looks like they would mount the shock in the remaining axis if I installed the spacer (that I don't have) between the tranny and the shock tower and ran the long wheelbase setup.
I might have answered my own question :mrgreen:
Yes that is what they are then. You need the shock tower spacer I believe.
BattleTrak
Has thanked: 1153 times
Been thanked: 624 times
Post by BattleTrak »
Arms are #7345 Jrx2 rear arm conversion kit.
-Brad
Return to “Identifications”
