Thats Losi blue, otherwise known as "blue".
RC10T3 Factory Team build
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2094 times
Re: RC10T3 Factory Team build
- Has thanked: 7 times
- Been thanked: 42 times
You could always send it out to get anodized. Granted a single part wouldn't be cheap, but it would match.
- Regular Member
- Has thanked: 10 times
Stunning build!
Ive got a t3 rtr version coming in a few days, but looks like it needs a bit of work (I sold an old kyosho lazer zx on ebay and it went for silly money, and I got excited when I finally found an rc10t... even though it cost me not far off what the new 6.1 would cost!!)
Anyway, where did you get the titanium turnbuckles from? Im looking for some for mind but cant find them anywhere, parts in the UK for the t3 seem to be even rarer than my original rc10 worlds parts!
- Lavigna
- Has thanked: 1099 times
- Been thanked: 1418 times
^ Crezo - These blue titanium turnbuckle are AE FT units that actually came with the FT (Factory Team) version of the truck. The T3 was offered in 4 different versions, with the FT being the most premium offered. The turnbuckle can be purchased separately as AE FT option parts.
I was lucky to receive these OG T3 decals.
I had to take a quick picture of it next to a XXT. Both have a decent amount of blue bling.
- Frankentruck
- Has thanked: 2604 times
- Been thanked: 2977 times
Very nice build. I appreciate you adding the bagged photos of the upgrade parts. They are a nice reference for T3 parts.
- MarkyDents
- Has thanked: 1809 times
- Been thanked: 643 times
That’s one bad A$$ FT T3 ! Can’t wait to see it completed.
Hey Cru ! Go balls out
If you run it, the blue aluminum outdrives may be gouged quickly. Do the instructions for the outdrives recommend some form of plastic covered pin (e.g. Schumacher U1918 blades or a thinner MIP puck) as an alternative to the steel driveshaft pin?
An example of a gouged outdrive can be found in the third picture of the following post.
https://www.rc10talk.com/viewtopic.php?f=36&t=45959
- Lavigna
Thanks for the heads up. If I run it I will probably replace the outdrives. They seem very delicate and I would imagine they would gouge very quickly. Also their opening for the pins is very tight. I had to file down the MIP pins just to get them to fit in the outdrives.Typpo wrote: ↑Wed Feb 24, 2021 11:34 am If you run it, the blue aluminum outdrives may be gouged quickly. Do the instructions for the outdrives recommend some form of plastic covered pin (e.g. Schumacher U1918 blades or a thinner MIP puck) as an alternative to the steel driveshaft pin?
I think I will put some vintage electronics in this truck and keep it as a shelfer.
- Lavigna
Front and rear springs installed. I also added some electronics. I'm not sure if they are era correct, or really go with this truck, but I thought they looked nice.
I replaced the aluminum MIP CVDs with some steel units. I polished them up to look like chrome.
I have some HPI wheels for the truck. Coming soon.
- Lavigna
I added a few goodies to this truck. Dragon front brace looks pretty cool imho. RPM steering.
I was thinking that RC10T skinny front wheels & tires would look good on this truck. I know it isn't accurate, but I may try it.
- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
Yet another stunning build!
You set the bar at nearly unobtainable levels for us mere mortals
Can't wait to see the body (no pressure).
Chuck
Chuck
- juicedcoupe
The matching rear wheels fit 1/4" axles, not the 3/16" that you have.
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
- 1289 Views
Last post by wunjee
- 1889 Views
Last post by JosephS
- 1147 Views
Last post by DHood
- 1143 Views
Last post by mikea96
- 30 Replies
- 4165 Views
Last post by KidAgain
- 31 Replies
- 6626 Views
Last post by erichevy
- 1987 Views
Last post by sschering
- 1212 Views
Last post by Gastruckracer14
