B3 axle help needed.
General info, Q&A.
rctenracer
Been thanked: 81 times
Post by rctenracer »
I just converted a b3 over to mip cvd's for a b2. The axles just engage the outdrive . Do i use down stops on the shocks to correct or am i just wasting my time. My b3 had 1/4" axles and just what to update to 3/16". The reason i did this because i cant find any b3 1/4" rims . I would like to sell the car but only if is correct.
Daddeo
Re: B3 axle help needed.
Post by Daddeo »
The CVD's for a B2 will be shorter by a little bit but you might be able to shim them out. It would be better if you could source a set of CVD's for the B3 specifically.
Has thanked: 356 times
Been thanked: 470 times
the outer axel half is spaced differently on the b3 the shoulder to pin is different
