wing wire
kaiser
wing wire
Post by kaiser »
what are you guys using to make wing wires ?
what size wire do i need?
thanks,
pete-
Re: wing wire
.078, i think.............. something like that.
craigc8791
Re: wing wire
Post by craigc8791 »
You can order them from rc10.com the part number is 6181
kaiser
Re: wing wire
Post by kaiser »
thanks gents!
craigc8791
Re: wing wire
Sure man glad i could help
smurf420
Re: wing wire
Post by smurf420 »
a paper clip is close to that size
tamiya_d1_junky
Re: wing wire
Post by tamiya_d1_junky »
what about for schumacher plated wire? what do you all use for that type?
I LOVE VINTAGE!!!
Vintagemishal
Re: wing wire
Post by Vintagemishal »
The wire we always used and some of my LHS's still carry is Piano wire.
Re: wing wire
yeah, there should be a selection of music wire at your LHS, typically used for airplane control links or whatever else. they have a bunch of sizes, and .078"does sound about right......find something close and cut and bend....just be careful, too tight a radius and it will snap.
drillNink
Re: wing wire
Post by drillNink »
kaiser wrote:what are you guys using to make wing wires ?
thanks,
pete-
piano wire from hobby shop...they have all sorts of sizes
u should find what u need
with age comes a cage
kaiser
Re: wing wire
Post by kaiser »
i found it @ hobbytown, i had to buy 3 36" sections.
anyone need any? lol
integra22t
Re: wing wire
Post by integra22t »
trying to find some too and found this on another site
4-40 x 1/4 nylon hardware made for the 1/10 scale bodies. used to mount Driver interiors, EDM bodies, Rear Spoilers, Roofs Side board wings. Best to use a number #32 wire size drill bit the drill diameter is .116 the drilled hole has a minimal fit.
littleVETTE
Has thanked: 6 times
Been thanked: 10 times
Re: wing wire
Post by littleVETTE »
i use K&S 1/16 music wire. lighter and a lot easier to work with. you could put a kink into it so the wing tubes could hold onto the wing and you don't lose it during a race.
http://www.ebay.com/itm/K-S-Music-Wire-36-062-1-16-15-K-S504-/360487095301?pt=Model_Kit_US&hash=item53eeb48c05
slapshot1979
Re: wing wire
Post by slapshot1979 »
I use stainless steel TIG filler rod from your local welding supply shop
