Schumacher CAT and odies
- Been thanked: 10 times
I got some bodies cheap there where 3 bodies and 1 undertray for like 5 dollars actually the shipment was more then i paid for the bodies.
1 just plain red and the 2 painted with polyca color ( kyosho )
and now the 3´d as you can see between the paint there is some stuff dont know what it is but you can clearly see it between the paint what can i use fore solvent that not harms the body ??? i will try to take away the stuff and leave the paint as is.
It is not as white in natural light the camera flash makes it appear more white then it really is.
look at the pictures and let me know what you think.
Was thinking of painting the background just plain white should look rather nice to the custom paint.
Btw where can i get the upper beltcover ????
mvh Isobarik
mvh Isobarik
- DerbyDan
- Been thanked: 17 times
Re: Schumacher CAT and odies
How strange? Could it be the remains of the spray mask that was used? Is it sticky - like the residue thats left when decals are removed??
I have a funny feeling it is spray mask...not sure how to remove it but perhaps you can try rubbing alcohol first. Failing which nitro fuel gets rid of alot of stuff but try it on a small spot first e.g fuel on rag then wipe.
- GJW
i have a protech body with the white stuff like your's, so it's spray mask ha, interesting.
best of luck getting it off dude.
Nope not sticky.DerbyDan wrote:How strange? Could it be the remains of the spray mask that was used? Is it sticky - like the residue thats left when decals are removed??
mvh Isobarik
Dont you think its possible to get of ????GJW wrote:i have a protech body with the white stuff like your's, so it's spray mask ha, interesting.
What about that DOT4 oil for cleaning it then ?????
Yeah thanks but wat soelvent ( alcohol ) doesnt harm the body ???uzzi wrote:I have a funny feeling it is spray mask...not sure how to remove it but perhaps you can try rubbing alcohol first. Failing which nitro fuel gets rid of alot of stuff but try it on a small spot first e.g fuel on rag then wipe.
Thanks shall try it but not over do it then with the brake fluid........
mvh isobarik
mvh isobarik
- Been thanked: 289 times
Word is that DOT4 brake fluid won't haze the lexan or make it brittle. I've never used it but I've seen that a number of times on different forums.isobarik wrote:Thanks shall try it but not over do it then with the brake fluid........
mvh isobarik
Nitro fuel will also work well. I imagine either one would be fine, but they'll also remove that red & blue paint.
Shall try for a start NOT to ruin the blue and red paint.Coelacanth wrote:Word is that DOT4 brake fluid won't haze the lexan or make it brittle. I've never used it but I've seen that a number of times on different forums.isobarik wrote:Thanks shall try it but not over do it then with the brake fluid........
mvh isobarik
mvh Isobarik
- 2973 Views
Last post by Eau Rouge
- 2063 Views
Last post by Typpo
- 20 Replies
- 2435 Views
Last post by QuackingPlums
- 1488 Views
Last post by GJW
- 914 Views
Last post by kenooze
- 1677 Views
Last post by terry.sc
- 114 Views
Last post by Dangeruss
- 1673 Views
Users browsing this forum: MarkyDents, radioactivity and 9 guests
