Rulux rims on a GT?
arf
Been thanked: 7 times
Rulux rims on a GT?
Post by arf »
Can anyone confirm that JConcepts Rulux rims for the T4 will fit my GT (it's not a GT2) with the same offset . The parts nos. are 3312 front and 3315 rear. They look bitchin. Thanks.
Has thanked: 358 times
Been thanked: 470 times
Re: Rulux rims on a GT?
They will
cautrell05
Post by cautrell05 »
Did the early GTs have the stepped 1/4 inch axle out back or were they all 3/16 from the get go?
Nick
All 3/16 as a rule-
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
cautrell05 wrote:Did the early GTs have the stepped 1/4 inch axle out back or were they all 3/16 from the get go?
Nick
not to argue with Reggie but some of the rtr's had 1/4" axles. I had 4 new ones out of the LHS and 2 had 1/4" and 2 had 3/16". These all were the first rtr blue flat chassis with the small nose tube holders. All of my FTGt had 3/16" factory direct and all ended up 3/16" in the end.
Has thanked: 3699 times
Been thanked: 1980 times
Nick
No wonder it's been such a PITA fitting wheels to mine over the years. Mine must have been 1/4" because I had to constantly drill out wheels to get them to work. :evil: It was either that or read up on what I actually needed instead of just buying the wrong ones... :oops:
klavy69
Moderator
Post by klavy69 »
Did you have to drill out your monster wheels like that thumber?
klavy69 wrote:Did you have to drill out your monster wheels like that thumber?
YUP. Both sets! :shock: You think I'd have learned after the first. :oops: :lol:
klavy69
Moderator
Post by klavy69 »
Arf. No matter what size its easy enuf and cheap enuf to change out your axles if you have the wrong size. I'm a tire guy so something like that is easy in my mind...as long as the other voices in there keep to themselves :mrgreen:
arf
Post by arf »
klavy69 wrote:Arf. No matter what size its easy enuf and cheap enuf to change out your axles if you have the wrong size. I'm a tire guy so something like that is easy in my mind...as long as the other voices in there keep to themselves :mrgreen:
The world will stop turning the day AE switches to 12mm hex rims.
Nick
I could have swore that the very first GT was a 1/4, three piece wheel with dogbones and stubs, instead of the solid 3/16 wheel and universals too, but all of my reference material only shows the latter-
Constant
Post by Constant »
Hey guys was wondering what tires I should put on the Black jconcepts rulux rims? Something along the lines of offroad and onroad but mostly on road... Badlands? or summit tires? I already have buggy tires and the gpm tires... I want the rulux because it'll make the wheel base wider...
arf
Post by arf »
Constant wrote:Hey guys was wondering what tires I should put on the Black jconcepts rulux rims? Something along the lines of offroad and onroad but mostly on road... Badlands? or summit tires? I already have buggy tires and the gpm tires... I want the rulux because it'll make the wheel base wider...
Are you putting truck rims on a buggy to make it wider? If so, here are your choices, all of the 2.2 size:
http://prolineracing.com/1-10-truck-tires-all-terrain
I love the way the Masher 2000 looks, but they're pretty high profile so beware steering throw issues depending on the body you use. Here they are on my HPI RS4 MT(possibly the least catchy name in R/C history :lol: ). They would look cool on a buggy in my opinion though. 8) Then again I'm the guy that always ran 4 Pumpkin tires on my Hornet... :wink: :lol:
Return to “RC10 Truck Forum”
