Frog adj motor mount. CNC alloy!!
- Mad Racer
Guys I saw this the other day and thought this is way better than the over priced fiberglass CRP version.
For S/Tune or stock silver can the little Frog really needs one extra tooth than the 19t pinion and this is the ticket.
I just bought 5 of them . ( 2 for me and 3 for my mates Frog/Brats.
http://www.ebay.com.au/itm/300702631509?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Cheers
Mark.
Cheers
Mark.
- Mad Racer
Re: Frog adj motor mount. CNC alloy!!
Will do guys.
There is another adj motor mount on the bay but after I inquired about it found that it only allowed the pinion to go down in sieze. Not what i wanted. The CRP version are still out there but mighty expensive for what they are.
We have 5 to 6 Frogs running at Boodal now with just S/Tune or silver cans and with stock gearing at the max . 49t spur 19t pinion they are still a little under geared even with the 2.2 wheels. So I will give this a go.
Will give the run down once I get them.
Thought I'd chime in
I have one. Purchased it for my Monster Beetle. Installs fairly easily and works a treat with larger size pinions.
Initially I was worried about the motor sliding around a bit, but it has proven itself to be quite solid.
I'm running an original and revitalized Trinity Monster Horsepower motor with a 18t pinion. Quite fun.
- ireg
Looking to re-build my frog as well, but need some parts,
that stuff is look good
- Mad Racer
That;s great news Thank You.eeeks wrote:Thought I'd chime in
- minimini
- Location: KWS@Hong Kong; 3.5 hours' trip to meet tiger1 and only 7,777 miles from Doug
- Been thanked: 11 times
I bought something similar last week......
http://www.ebay.com/itm/120909174868?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
- Mad Racer
I contacted CRA about this motor mount & he told me that it only allowed for smaller pinions not up as well.
Pitty as they look really good.
- uniquenamehere
- Lowgear
- Has thanked: 121 times
- Been thanked: 796 times
I placed an order with that CRA once and the hardware was just thrown in with the parts thus scratching them all.
I messaged him about it and suggested he put the hardware in its own separate bag. I don't know if he ever took my advice or not.
- Mad Racer
Update.
I bought 5 of these 3 for me and 2 for my mates with Frog's.
Came very well packaged & with all the nuts & bolts to fit it up. The only problem I had is the Frog's gear case & side plate (motor side) had to be enlarged with a dremel . To allow the 20 tooth pinion in. The short Mabuchi motor shaft just reaches the spur as it's spaced out with the plate.
In stock silver can the little Frog was a tad under geared even with the 2.2 wheels. So this is great to have the adj motor mount.
- 1217 Views
Last post by pottok
- 679 Views
Last post by Mr. ED
- 624 Views
Last post by GoldRush
- 1990 Views
Last post by klavy69
- 1338 Views
Last post by Mad Racer
- 21 Replies
- 3281 Views
Last post by Justjoe
- 19 Replies
- 1708 Views
Last post by slotcarrod
- 2963 Views
Last post by Lonestar
