RC10T runner shock mounting question
I have a question about a 10T runner project I have going. It's a mix of a bunch of parts I had laying around and I need an opinion on mounting the rear shocks. I'm using T4 rear shocks, a 10T team truck rear tower, and 10T RPM rear arms. The shocks are mounted towards the rear of the shock tower on the T4 and forward on the 10T. When I hold the shock up to the forward position, the bottom of the shock is super far away from the arm mounting point. My question is, should I mount them forward and use nylon spacers and a long screw or can I mount them behind the tower so the bottom mount lines up better? The body I'm using allows for both options. If anyone has used a similar setup on their trucks I'd love to see a pic. I'll try and post a pic this morning of what I'm working with.
- Rusty-Racing
Re: RC10T runner shock mounting question
The t4 and t shocks are the same dimetions so there should be no issues when using them. I would say your inner arm mount for the rear arms is mounted in the wrong holes when it was mounted to the chassis thats why they arent linning up. Take a look at them and make sure they are all the way forward. You have pics?
- Charlie don't surf
- Has thanked: 280 times
- Been thanked: 379 times
I thought I replied to this in the AM.......guess not
your in the LWB setting @ the toe blocks (which is just fine as it makes the truck more stable and easier to drive overall) this means you have to add a spacer at the bottom shock mount to reduce binding- or mount on the backside of the tower- (v1 T4 shocks on my outdoor truck in SWB with 3 deg inboard toe in)
HAHA I'm silly, I forgot to check that. This truck will mainly be a basher but I'm trying to get my friend into racing so I have a buddy to race with. I think I'll leave the blocks where they are to aid in stabillity and try to mount the shocks using a spacer. Thanks again for your help. This site has been a great help to me.
- Has thanked: 7 times
- Been thanked: 42 times
Don't forget that there's supposed to be the three-hole lower shock mount that gets bolted to the arm as well as the lower shock bushing with the built-in spacer to space the shock away from the arm.
- Attachments
- rc10t lower bushing.jpg (14.15 KiB) Viewed 1151 times
- asc7657.jpg (14.4 KiB) Viewed 1151 times
Thanks everyone for your help, I got the shocks all sorted out last night and everything is working fine with no binding. I'll post a few pics when I get home from work.
- 737 Views
Last post by JosephS
- 22 Replies
- 4551 Views
Last post by TokyoProf
- 1181 Views
Last post by call-911
- 23 Replies
- 3216 Views
Last post by HKS_TRD
- 1232 Views
Last post by THEYTOOKMYTHUMB
- 281 Views
Last post by mrlexan
- 1201 Views
Last post by Twiceblown351
- 37 Replies
- 12985 Views
Last post by jaro
Users browsing this forum: Amazon [Bot] and 4 guests
