RPM Rear Hub Carrier Set RPM70172
- Has thanked: 35 times
- Been thanked: 10 times
Hi guys,
I want to use these on my T3 but can't seem to work out wich CVD's to use. Standard T4 CVD's are way to short. Does anyone has experience with this?
thanx!
thanx!
Re: RPM Rear Hub Carrier Set RPM70172
You will need T4/GT2 axle stubs with T3 shafts.
thanks for teh quick reply!
so you meen the 9670 axle from the GT2 combined with the T3 cvd bone ?
i´ve just checked, but that can´t be right? I want to use the CVD....The stub axle combination on the GT2 is te same as that of the T4 and that doesen't work on the T3.
Should I perhaps use the gt2 cvd bone combined with the t3 or t4 axle?
Am i wanting something impossible?
- teman
- Been thanked: 6 times
The 7027 set is a better fit and Avid makes 3/16X1/4 bearings for them
Do you have the 7027 set by chance?
-Kevin
great info Teman!
No I have the RPM 70172. Idea behind it all was also to widthen the rear a bit. If i'm correct that is not the case with the 7027. So in the end my plan with the RPM 70172 hubs is not possible.
So, now i will try to find a pair of RPM 7027 hubs (with the AVID Bearings off course!
- teman
Compared to either stock hubs it will raise up and extend out the rear wheels a little. I'll take a photo when my camera battery is charged.
The newer stock 0 degree is on the left, the later stock 3 degree is on the right. I've test fitted the RPMs, I just never got around to running with them this year
-Kevin
great info, thanx
curious how they will perform, with the raising of the wheels and all. Let me know when you had the time to run them
Have to wait when a pair shows up on the internet. Recently there was one, but the shipping alone was $20
- teman
No problem at allbroodenburg wrote:great info, thanx
curious how they will perform, with the raising of the wheels and all. Let me know when you had the time to run them.
I'll run the T3 again soon, I just need to order the bearings from avid
I'm pretty sure the newer set will work on the older trucks, we just need to figure out what combination of parts work best together.
-Kevin
It's unfortunate RPM stopped producing them.
if you have new info on the AVID bearings let me know!
teman wrote:The 7027 set is a better fit and Avid makes 3/16X1/4 bearings for themDo you have the 7027 set by chance?
http://www.ultimatehobbies.com/store/RPM70272%211001/70272+CARRIERS+W%2FO+BB+RC10GT
― Confucius
― Confucius
- teman
These are the bearings that Avid makes for these hubs
http://www.avidrc.com/product/1/bearings/75/14-x-12-x-316-Revolution-R188-RSZ-bearings.html
-Kevin
RPM Hubs and AVID bearings are ordered.
Very curious how they perform!
@ teman:
i just received my RPM hubs
I also received the AVID bearings
http://www.avidrc.com/product/1/bearings/75/14-x-12-x-316-Revolution-R188-RSZ-bearings.html ,
however they don't fit!!!! Inner hole is to big for the axle. outer size is correct.
what you need (I think) is this:
http://www.avidrc.com/product/1/bearings/117/316-x-12-x-49250-Revolution-R3-RSZ-bearings.html
Am I right?
Am I right?
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
if you have 3/16" axles then yes...that should work. Hard to say what your truck has without seeing pix
thanx for the lightning quick response Todd!
3/16" axles are what I have. So i'm good I guess.
I've contacted AVID because it seems their site offers incorrect info.
I'll post the results as soon as the bearings arrive here in The Netherlands.
perhaps I'll even post some pictures ....
- 656 Views
Last post by broodenburg
- 944 Views
Last post by Kyosho Fan2
- 1285 Views
Last post by Y'ernat Al
- 1226 Views
Last post by 66intheSky
- 537 Views
Last post by slotcarrod
- 1244 Views
Last post by Group B
- 1626 Views
Last post by SUPERDAD
- 1008 Views
Last post by minimini
