rims and tires for worlds car
General info, Q&A.
Alberta guy
Post by Alberta guy »
I'm in the process of tracking down parts for my rc10 worlds car rebuild. I can find pretty much everything I need to replace or have a spare of from tower hobbies with the worlds car re release. The only thing I cannot find is rims and tires. Searching through the forums depending on the post some say upgrading to wheels works and others say it doesn't. What do i do?
Been thanked: 3917 times
Re: rims and tires for worlds car
Worlds car were 1/4" axles, the ReRe is a 3/16 conversion using late model wheels. They won't help you unless your going the runner route, then by all means convert to 3/16 cvd's and late wheels
Alberta guy
gomachv wrote:Worlds car were 1/4" axles, the ReRe is a 3/16 conversion using late model wheels. They won't help you unless your going the runner route, then by all means convert to 3/16 cvd's and late wheels
is it possible to just drill out the rims to 1/4"? They way things are going so far I'm ready to just buy something brand new and toss these in the garbage.
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Post by Asso_man! »
Possible probably, but certainly not an easy solution an it won't be durable either. On top the 1/4 axles have a bump where the 3/16 are straight all the way. If it's runner do a conversion, if for the shelf find proper vintage wheels.
Come and visit the stable
harvey
Post by harvey »
I have used a counter sink to allow the 1/4 " axles to sit into a 3/16 " rim. You want a small one, with a 1/4" OD.
You'll need to enlarge the pin slot in the rim with a dremel ball engraving bit.
Next, when you mount up you'll see the threaded 1'4 " axle is smaller than the 3/16 ", so take a piece of wing tube and drill it out to slip over the axle threads, trim it to fit the remaining straight bore in the rim (this needs to be precise; the axle nut will press it onto the axle if it's too long) , and you should be good.
Having done this in the past, I think I'd opt for a properly fitting rim/axle combo if at all possible!
