Tamiya BigWig #6
THE H.P FREAK
Tamiya BigWig #6
Post by THE H.P FREAK »
HI!... This is Tamiya BigWig #6. This one will have a ton of after market parts that were designed for the BigWig. This is what I got put together so far. Waiting on some more parts to show up.
- Parma = Kydex front bumper
- Dirt Burners = Gear box support
- Parma = spiked tires front/rear
- Dirt Burners = front/rear sway bars
- Dirt Burners fiberglass rear shock tower
- Vintage receiver
- Vintage ESC
- Full ball bearings
<a href="http://s361.photobucket.com/user/Neal330ci/media/Tamiya%20BigWig%20number%206/Img_6277.jpg.html" target="_blank"><img src="http://i361.photobucket.com/albums/oo58/Neal330ci/Tamiya%20BigWig%20number%206/th_Img_6277.jpg" border="0" alt=" photo Img_6277.jpg" style=""></a>
THE H.P FREAK
Re: Tamiya BigWig #6
HI!... Well started working in this one as well. I didn't paint the body, it came with another car but the body was new and painted very well. Just not my choice of colours. lol. Might do something similar, but with blue/white/orange. I added a few decals to it to make it look better for now.
broodenburg
Has thanked: 35 times
Been thanked: 10 times
Post by broodenburg »
stunning car stunning paint job also!
Nice option parts. Half of them I never knew they existed... :shock:
That's weird that the motor wire routing zip-ties in that particular location, which causes the body and wing to be crooked, pushed up on the right side. It looks like that on all your Bigwigs. If it were me, I'd file or Dremel a little notch in the black tub at the rear, allowing the motor wires to route directly into the tub. Kind of a design oops by Tamiya, IMHO. Just a thought. :)
EDIT: Although I like the notch idea better, after a closer look, it appears that the motor wires are intended to route down into the tub, as there's a recess there to permit that; the recess doesn't exist on the opposite side of the tub.
THE H.P FREAK
HI!... The wires are designed to run on the rim of the chassis. Tamiya pre drilled holes in that location to fasten the zip ties. No room to run the wires in the chassis. The 8.4 Volt battery kust barely fits itself. If I were to cut or notch the chassis the chassis would lose all its value.
THE H.P FREAK wrote:HI!... The wires are designed to run on the rim of the chassis. Tamiya pre drilled holes in that location to fasten the zip ties. No room to run the wires in the chassis. The 8.4 Volt battery kust barely fits itself. If I were to cut or notch the chassis the chassis would lose all its value.
I think I need to clarify. Yes, you zip-tie the wires where Tamiya pre-drilled the slits, but there's a notch for you to stuff those rubber-sheathed connections down inside the tub. I don't think they're supposed to be on top. The body & wing aren't supposed to be crooked. I hope this pic helps; try it. No drilling needed.
THE H.P FREAK
HI!... That notch is for the battery leads. The bottom under the battery is only about 1/16 deep. Not enough room. The receiver antenna wire barely has enough room to get under the battery without causing interference problems.
Alrighty then. :) I built a Bigwig back in the day, I just figured I'd point something out as all of your recently posted Bigwigs have a crooked body/wing due to the placement of your bullet connectors. Keep them crooked if you like, they're your cars. :?
THE H.P FREAK
HI!... If they are built by the manual they will have a crooked body. :mrgreen:
THE H.P FREAK
HI!... I have updated the modded BigWig now. It now has :
- Hotshot aluminum driveshaft
- HPI 5 spoke white wheels
- Twister brushed motor
- After market aluminum shocks
I plan on making a "fake" 9.6 volt NiMh battery for it also. Currently painting another body for it as well.
I like the wheel & tire combo, it looks good on there...aggressive! :twisted:
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Post by Lonestar »
traxxas shocks?!?! :shock:
the front dynamites don't look as good as stockers in my book...
still a good-looking car nonetheless!
broodenburg
very cool! one of my all time favourits!
THE H.P FREAK
HI!... Got some work done on BigWig #6 this weekend. Bought a driver figure and got him painted up and mounted in the body. Also got some BigWig decals applied to the body.
Return to “Tamiya Forum”
Users browsing this forum: No User AvatarAmazon [Bot], No User AvatarBing [Bot] and 12 guests
