Anyone mill a powder coated chassis?
- mk-Zero
- Business Member
- Has thanked: 4 times
- Been thanked: 21 times
Has anyone done World's style milling on a powder coated chassis? A buddy of mine asked if I would mill his but we are afraid the powder coating may get messed up at the sides of the milled areas? Anyone have any experience with this?
Re: Anyone mill a powder coated chassis?
it probably will get a little 'furry' on the edges, especially if the area you are milling gets warm. Might not be so bad if you are using a water spray on the mill.
sorry, not much more useful than that.
- mk-Zero
- Business Member
Thanks for your reply. Can the edges be cleaned up after with an xacto knife? Got any pics?
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Figure it out...I have some PC chassis too
same color I bet!
- mk-Zero
- Business Member
Sorry, I don't have any pictures. I would expect that if the prep work was good, you can trim up the fuzzy edge with a sharp blade afterward. The only concern is that the prep being poor would result in lifting on the non machined area. aluminum is a pain in the butt, nothing really sticks to it well.
- mk-Zero
- Business Member
Thanks. I guess there's only one way to find out...
Now who's going to volunteer first: Justin or Joey?
- mk-Zero
- Business Member
I milled a powdercoated chassis and it came out great. I just had to clean up a few edges with a razor, but only because the coating was hanging down in the milled areas. The coating at the edges of the milled areas is perfect once you clean it up.
I masked the bottom and sides of the chassis with blue painter tape to protect the coating
Squaring it up on the mill
And finished
And finished
- mk-Zero
- Business Member
Thanks guys!
Yeah, the red with the milled accents looks pretty sick. He's going to build the car with white plastics, should look amazing!
- JK Racing
Mine is built all black plastics, but needs that milling love
- 547 Views
Last post by RC10resto
- 1113 Views
Last post by Kev90sc
- 815 Views
Last post by sandkil
- 608 Views
Last post by Mr. ED
- 43 Replies
- 6651 Views
Last post by THEYTOOKMYTHUMB
- 1541 Views
Last post by klavy69
- 2599 Views
- 181 Views
Last post by JosephS
