The upper Deck original CML Dreshar, now you can get a repo from fibre-lyte but you wont find an original like this one, you would have more of a chance trying to find hens teeth, the dampers are original Team associated factory team shocks that alot off the top drivers use to run and if you look closely they are the exact same ones that masami and all the other factory drivers use, you maybe a little confused because it doesnt look like your traditional 94 yz10 but thats only because there are so many factory team hop ups on their how ever your right about the bumper bar it is an original RPM lol i have it on there just for now as i have an original on the way, but you didnt do too bad one out off four isnt bad LOL.crusaderlyf wrote:after market or custom upper deck. non stock body set、bumper、 tyre set, May be also the damper set
I can't remember Craig Drescher or CML offering an option chassis for the 1994 Yokomo YZ10. In my opinion, the chassis on your car is a Yokomo OEM item (ZD-115).The upper Deck and chassis are original CML Dreshar, now you can get a repo from fibre-lyte but you wont find an original like this one, you would have more of a chance trying to find hens teeth
Nahand that body was the one supplied in the kit
They look like standard Team Associated hard anodised/teflon coated shocks. Are they new or used?the dampers are original Team associated factory team shocks that alot off the top drivers use to run and if you look closely they are the exact same ones that masami and all the other factory drivers use
I can see a carbon fibre upper deck, Kyosho steel turnbuckles on the rear links, carbon bellcrank support, extra holes drilled in the front shock tower and a Yokomo TCS. Can you tell us about the other Factory Team hop ups? Congrats on finding a new OEM ZD-111 front bumper. Quite rare.you maybe a little confused because it doesnt look like your traditional 94 yz10 but thats only because there are so many factory team hop ups on their how ever your right about the bumper bar it is an original RPM lol i have it on there just for now as i have an original on the way, but you didnt do too bad one out off four isnt bad LOL.
