Track Master belt drive
- KidAgain
- Business Member
- Has thanked: 513 times
- Been thanked: 431 times
Would it be possible to convert it to direct drive? Is it just swap out the belt drive gear and top shaft with a spur?
Thanks
Jake
Thanks
Jake
- KidAgain
- Business Member
Re: Track Master belt drive
Okay let’s see how much brushless power I can lay on it then if it doesn’t work out plan B ( my machinist ).
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
I don't have experience running a Trackmaster trans but I've read that the belts on them tended to slip. That makes me doubt the trans would do well with a brushless. I'm also not sure if the direct drive version would do much better because of the small diif rings the trans uses.
- KidAgain
- Business Member
Kind of bummed with that news but I will tread ahead and try it, I want to lock the diff also or find a spool for this trans.................
- ChisaiKuso
- Has thanked: 5 times
- Been thanked: 27 times
The odds are good that you will wind up damaging vintage RC parts. Why even risk it?
Something clever goes here...
- KidAgain
- Business Member
I get it but I don’t let stuff like that bother or stop me though I have my ace in the hole as always my machinist.ChisaiKuso wrote: ↑Mon Apr 22, 2019 7:11 pmThe odds are good that you will wind up damaging vintage RC parts. Why even risk it?
- KidAgain
- Business Member
Decided to get the parts Cryo treated to add some strength to the gears and shaft may do the same if I run a metal spur for the drag racer build. See how this works out..........
- 2832 Views
Last post by Lou0151
- 2510 Views
Last post by fredswain
- 835 Views
Last post by aconsola
- 3088 Views
Last post by Lowgear
- 1408 Views
Last post by LaserRC10
- 1996 Views
Last post by blubblood
- 23 Replies
- 3590 Views
Last post by jcwrks
- 1277 Views
Last post by NCOHOG
