#6002 - RC10 Worlds Car Kit
Re: #6002 - RC10 Worlds Car Kit
Thanks guys for the answers.
Just ordered some pinions gear from 21 to 28.
I will follow your advices and start from 21-22 going up...
Cheers
Cheers
- besty22
Well, just built most of my rere Worlds kit. I have an original Worlds kit and remember how the gearbox would spin free as a bird. I remember because at the time I was amazed how good the quality was compared to my , at the time, Tamiya kits.
Sad to say the rere is not a patch on it. Its gritty/notchy and the slipper plate rubs as well. I think the slipper is actually rubbing on the screw heads which hold the gearbox to the motor plate, not the motor plate itself.
So I have two questions.
Has anyone run in a gearbox to see if it frees up?
Do you think it would be ok for me to back off those gearbox-motor plate screws so the slipper doesnt rub? I have threadlocked them
Otherwise its gonna be a painful exercise for me to get parts sent from AE to good old OZ
Any opinions / answers appreciated.
Cheers
Besty
Cheers
Besty
Respect - Hard Earned but Easily Lost
- sandkil
- Has thanked: 795 times
- Been thanked: 623 times
There is at least three parts that needs to be looked at:besty22 wrote:Well, just built most of my rere Worlds kit. I have an original Worlds kit and remember how the gearbox would spin free as a bird. I remember because at the time I was amazed how good the quality was compared to my , at the time, Tamiya kits.
Cheers
Besty
The gear case.
Idler gear.
Top shaft.
If I understand it correct the:
Top shaft is wrongly machined. Replace with B4 top shaft. ASC9601
Idler needs to be the old type with fixed axle. ASC6570
Case halves needs to be ordered from AE or Amain. ASC6565
Here is a link to gomachv thread/video that digs into the issues:
http://www.rc10talk.com/viewtopic.php?f=88&t=36121
/Erik
- besty22
Thanks Eric. I will just order the correct parts.
Cheers
Chris
Cheers
Chris
- Has thanked: 25 times
- Been thanked: 143 times
well i finally broke down and ordered the rc10 worlds kit. got it at a mian for $179 shipped plus found a new pair of orginal rc10 worlds front wheels else where online. prob going to search for orginal worlds shocks next.
- RC104ever
Hey everyone - I'm almost finished building my rere World's kit. The transmission is tight but I'm going to run it HARD and see what happens.
But my question for you all is - how in the heck are you supposed to get the battery holder on and off? If you screw in the screws (not all the way I'm guessing), you can squeeze the sides of the battery tray when there isn't a battery in there. But once you put a battery in, there's no way to get it out. I'm thinking of swapping them for the thumb screw holders.
- Chris
Lots of cars...so many cars
- Has thanked: 100 times
- Been thanked: 205 times
RC104ever wrote:Hey everyone - I'm almost finished building my rere World's kit. The transmission is tight but I'm going to run it HARD and see what happens.
Shouldn't need to squeeze the box, slot the slotted side over one screw and then slide it into the locked position then drop the non slotted hole over the other screw and run a body clip through the hole in the head of the screw to secure the battery strap.
Chris
Edit.. hmm may not be possible on the worlds car, never had one of those straps, oops.
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
- RC104ever
I wish it was as easy as the older ones! Doesn't seem to make 'sense' on the World's car. There SHOULD be some kind of screw with a hole in it that you can put a body clip through it and that would make sense. But both sides have larger holes and its tight on both sides to literally the only way to get the holder off.
- Chris
- slotcarrod
- Been thanked: 45 times
For Lipo's I reamed out the holes a bit larger and used both screws with body pins. I also ground down the part of the battery strap that slides under the rear bulkhead/battery slot. About half the width, but I use pretty thick Reedy 5500 packs.
Rod Littau
- flipwils11
- Been thanked: 19 times
Was there ever a final answer on this?flipwils11 wrote:That's what I'm wondering.hugger19 wrote:so thats it the rc10 worlds run is over?
- THE H.P FREAK
HI!... Well I've had my RC10 World's car for about 5 months now. Decided to finally put it together last night. All I can say is I'm very disappointed in the quality. 1st off almost every bag in the kit was missing something. Missing screws, washers, nuts. Not enough "o" rings for the shocks, 1 shock pivot dowel was missing. Went to put the Stealth trans together and no idler gear! Plus the slipper clutch rubs, and the countersink holes on the chassis are not deep enough. Who builts these kits? 5 year olds!!!!!!!
- flipwils11
The 5-year-olds build the RTR kits for Traxxas.THE H.P FREAK wrote:Who builts these kits? 5 year olds!!!!!!!![]()
- Has thanked: 36 times
- Been thanked: 1318 times
- Has thanked: 1129 times
- Been thanked: 3919 times
Just saw that race roller version.
apparently for those that want a classic kit without having to do a nights worth of work building it
- 2766 Views
Last post by sandkil
- 1056 Views
Last post by carloco8
- 4320 Views
- 2089 Views
Last post by XLR8
- 866 Views
Last post by RogueIV
- 1534 Views
Last post by AndrewCooke
- 1181 Views
Last post by ASC6000
- 2468 Views
Last post by mytimac
