screw kits?
General info, Q&A.
dbs179
Re: screw kits?
Post by dbs179 »
scr8p wrote:They are 100 degree, not 102.
Ok, I found tons of 100 degree screws, just no 102, or 82 degrees.
Thanks again,
Dave
Thanks,
Dave
Re: screw kits?
RanchoJim
Re: screw kits?
Post by RanchoJim »
Maybe these are a bit stronger? (100 degree 8/32 phillips)
http://www.chiefaircraft.com/hd-ms24693c8x.html
Re: screw kits?
yes those screws would work nicely.
honestly, I believe they used 100 degree countersinks on the entire chassis, and should use 100 degree screws all around. using the #4 screw that are 82 degrees are why the heads stick out proud of the surface of the chassis. always bugged me.
85Edinger
Re: screw kits?
Post by 85Edinger »
So there are alternatives? I'll have to give those a try.
RanchoJim
Re: screw kits?
Post by RanchoJim »
Installed them and they work great. They mount perfectly flush.
alien3t
Re: screw kits?
Post by alien3t »
http://www.boltdepot.com/Default.aspx usually a little cheaper than fastner express.
http://www.albanycountyfasteners.com/ for stainless steel (but they dont have the 100 degree 8/32) after your order comes ot 19 bucks shipping is free. one of the cheapest i have found for or per screw.
NickTheGreek
Re: screw kits?
Post by NickTheGreek »
I had bought the Tony's Screws a couple months back....
The chassis screws that come with that are a complete waste.....n you get a lot of em too.
Then you get a bag of these 2/56 screws.....a bunch of em....I don't know what their purpose is....
But I give this Tony guy credit for one thing.....
He ain't hiding from the fact that he screws you.......He gives you the stickers right with your package that read "you've been screwed by Tonys screws".....n this brother got balls. Not only does he stick it to you with the stickers, he even includes his business card.
That brothers gangsta
Been thanked: 3917 times
Re: screw kits?
Copycat! Trinity had the you've been screwed gimmick in the late 90's!
janaya
Re: screw kits?
Post by janaya »
I'm not sure why but I just ordered a set of the Protek titanium screws that Amain sells for the world's car re-re. I really wanted to use a coupon for my order and needed a few more $ to get to the minimum, so I just figured why not. I'll post up if I feel it was worth it.
Javier -
