Reviving a Stealth CE and other RC10's
Jimbo302
Has thanked: 14 times
Re: Reviving a Stealth CE and other RC10's
Post by Jimbo302 »
I have some traxxas parts and a RC10 tub with a traxxas transmission and rear suspension. Would I be out of my head to try and assemble a runner? I'm going to say yes, and pass on the idea.
I decided to save the RC10 pan and threw the Hawk rear end on an old dilapidated nitro rustler.
DaveM
Has thanked: 727 times
Been thanked: 26 times
Post by DaveM »
Jimbo302
Post by Jimbo302 »
DaveM wrote::|
Yeah, I thought it through and put the parts away, lol.
DaveM
Post by DaveM »
:D
Jimbo302
Post by Jimbo302 »
Edit saved for ce
Jimbo302
Post by Jimbo302 »
Back on track with the Stealth CE.
It's is a
Jimbo302
Post by Jimbo302 »
Well if I am ever going to put the Stealth CE together, I'm going to have to
DaveM
Post by DaveM »
Hi Jimbo,
Get to work then! :lol:
You won't need the 10L front mounts or truck arms.
If you want to part with the RPM white front arms for a 10T, let me know.
I have had a pair of rears for at least 6 years. :roll:
Jimbo302
Post by Jimbo302 »
Yes, I had just added a few parts to the cleaning pile. The rpm arms are going on the next truck.
The Stealth is done, I
Jimbo302
Post by Jimbo302 »
Everything scrubbed, checked, repaired, lubed and mostly reassembled on the Stealth CE. I am waiting on some shock
lmw94002
Been thanked: 9 times
Post by lmw94002 »
Looking good!
--Builds--
Jimbo302
Post by Jimbo302 »
Thanks. It's just a soap and water rebuild, but I feel like it looks better.
What options do I have for wheels to run modern rubber? I put stickier tires on the fronts and It has some sort of one piece wheel on the rear, but it's a smaller diameter.
lmw94002
Post by lmw94002 »
modern offroad or onroad rubber? Guess it also depends if you want "vintage" style rubber or are looking for something being used on a track today...
--Builds--
Jimbo302
Post by Jimbo302 »
Off road with some pavement use. I guess ill have to look around. I modified a set of wheels for a T4 to fit my 10T, maybe I could do the same with this one.
I'm still a bit away from needing that though. The newest snag, is that the rear arm pin is too short for the rpm arms. Edit: I found a longer
Rpm was selling the right hinge pins for those arms.
