- Goatless
If its close to 1/4' thick, Scr8p told me mine was a raceco chassis. Its in this thread as well
"I'm like the fat girl at the prom, just glad to be here!!!
Southern Fried Racing : The Sequel
Thought so too....But it is only .130 thickGoatless wrote:If its close to 1/4' thick, Scr8p told me mine was a raceco chassis. Its in this thread as well
it does have the same rough shape as a TQ chassis, but the corners are too rounded. Of course someone could have rounded off the outer corners, but not the inside corners, which appear too rounded, such as behind the rear wheels where the chassis goes from thin to narrow.
the picture isn't too great, how does the carbon look? is it like a weave or are all the fibers aligned in one direction? also, what does the cross-section look like?
does it look like someone modified the chassis in the front where it goes from thin to narrow? maybe that is what I am seeing.
- Has thanked: 36 times
- Been thanked: 1318 times
- GJW
is that because it's not glossy on the top surface and cut a little differently jas?scr8p wrote:it's an early tq10 chassis.
the dead giveaway that it's an early tq10 chassis, 2 actually, is the offset battery box and the nose plate screw hole between the steering bellcrank. the one where you'd install the 8-32 x 1/4" screw to attach the nose plate on a tub chassis. they obviously used the same drill jig as the tub chassis on the early ones.
- GJW
sheesh!!! talk about observant man, i thought i was decent but have nothing on some of you guy'sscr8p wrote:the dead giveaway that it's an early tq10 chassis, 2 actually, is the offset battery box and the nose plate screw hole between the steering bellcrank. the one where you'd install the 8-32 x 1/4" screw to attach the nose plate on a tub chassis. they obviously used the same drill jig as the tub chassis on the early ones.
Sorry...Had some Dimsum that was calling my name...
I thought it was an early TQ but wasn't sure because the smaller holes along the sides aren't c'sunk
So now its got me thinking....why would the battery box holes be offset ... shift weight to one side ?... its offset by about .425...chassis for oval track,but then it would have to be run opposite directionscr8p wrote:the dead giveaway that it's an early tq10 chassis, 2 actually, is the offset battery box and the nose plate screw hole between the steering bellcrank. the one where you'd install the 8-32 x 1/4" screw to attach the nose plate on a tub chassis. they obviously used the same drill jig as the tub chassis on the early ones.
you have to look at gene husting's prototype to understand the reasoning for the offset battery box holes.
http://www.rc10talk.com/viewtopic.php?f=35&t=5058
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Hey Guys, certainly not as glamourous as an early TQ10 but can someone tell me what is this thing?
Looks very cat-esque to me, but not from the mighty traxxas... any idea? It was a friend's first RC and now he wants to find one, so obviously the name would help
Cheers
Paul
Cheers
Paul
does it say jet hopper on the wing section? is it full size 1/10? i know tyco made a jet hopper but it was samller then 1/10.
it certainly looks very cat'ish.
- civilguy
- Has thanked: 5 times
- Been thanked: 14 times
It looks like your friend may have had a Traxxas Cat with a different (toy store brand?) body on it. That's my first impression.
Edit: found it: http://tamiyaclub.com/showroom_model.asp?cid=88773&id=25101
Must be a later version body.
Jeff
Jeff
- 59 Replies
- 16056 Views
Last post by Diamond Dave
- 106 Replies
- 27075 Views
Last post by mikesofunny
- 431 Replies
- 54339 Views
Last post by Eccentric
- 67 Replies
- 16809 Views
Last post by bearrickster
- 321 Replies
- 41816 Views
Last post by tazz888
- 448 Replies
- 49911 Views
Last post by MelvinsArmy
- 351 Replies
- 47417 Views
Last post by Frankentruck
- 4196 Views
Last post by mrlexan
