spur gear needed for RC1
tvr4
Post by tvr4 »
I have an Associated RC1 nitro RC car kit and am in need of the large spur gear.
The parts manual list it as 820-65 "Autolube spur gear 65 teeth"
Is it possible to purchase this gear or something similar?
Thanks
a01butal
Has thanked: 34 times
Been thanked: 40 times
Re: spur gear needed for RC1
Post by a01butal »
Message reign79 as he is Mr Associated when it comes to early 1/8 Associated on-road cars, he's on here and also facebook but he'll probably see this sometime soon.
This is all very interesting!
Lowgear
Has thanked: 121 times
Been thanked: 792 times
Post by Lowgear »
You might be able to find something that's a currently produced equivalent. It's a simple shaft mount spur gear from the looks of it.
You'll need to know a few dimensions along with the gear pitch for example. Gear teeth also have different pressure angles (Generally 14.5° or 20° in this size range.) but who knows what Associated went with in this application.
If you search around the net, there's a lot out there in the way of these particular gears.
tvr4
Post by tvr4 »
Lowgear wrote: Tue May 05, 2020 7:08 pm You might be able to find something that's a currently produced equivalent. It's a simple shaft mount spur gear from the looks of it.
I did that already and found nothing. The gear is 65T and 25P
It is a simple set screw that holds it on the axle shaft
Lowgear
Post by Lowgear »
What's the bore diameter? I'll look at the places I buy gears from. You might have to settle for an all metal gear or one down a tooth.
tvr4
Post by tvr4 »
Lowgear wrote: Wed May 06, 2020 4:00 pm What's the bore diameter? I'll look at the places I buy gears from. You might have to settle for an all metal gear or one down a tooth.
About 1/4"
I measured 6.5mm
Lowgear
Post by Lowgear »
Those are odd specs overall. I wonder why they didn't go with something more standard. I'm having difficulty finding anything as well. I can find gears that would work in 24P but nothing in 25P. There doesn't seem to be 25P gears in general.
tvr4
Post by tvr4 »
Agreed. Maybe it was standard back then. I don't know
But could I use a 24P gear as long as it was 65T ?
The kit came with an optional 63T gear but I do not know the specs and we did not have one
Here are a couple of pics I found online of the gear mounted on the vehicle
V12
Been thanked: 100 times
Post by V12 »
Contact Classic RC museum for Associated 1/8 spares https://classicrc.wordpress.com/about/contact/
RC10resto
Has thanked: 1487 times
Been thanked: 550 times
Post by RC10resto »
Not sure if this will work for you?
