Bud's Motor Dyno
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
Bud's Motor Dyno
Just getting this started. It'll be a little while before I can put any data together.
Anyway, I picked up this Bud's motor dyno, complete with box, instructions, and a couple motors.
- juicedcoupe
Re: Bud's Motor Dyno
First, I had to make a couple small repairs. It came with self-tapping 8-32 screws, which had partially stripped and damaged the phenolic plastic base.
I replaced them with studs, installed with CA glue.
- juicedcoupe
I got the scanner linked up with my tablet and was able to scan the directions.
I also scanned the data sheet. For some reason, the scanner removed the header from the page.
I also borrowed a page from the Tekin dyno manual, about making a dedicated slave motor.
- juicedcoupe
I built the slave motor and decided to try it.
Apparently, the cheap Kobalt DVM that I bought doesn't range very well, so I had to use my Fluke. Or at least, I might need to learn how to use a cheap meter.
I didn't try to get any useabe data, just verifying that it loads up and displays some type of data.
I've also got to figure out how to adjust the auto-range on my Fluke meter.
- coxbros1
- Has thanked: 2758 times
- Been thanked: 2407 times
That's what I remember from the 80s....it never told rpm, just a random # that u had to use as a reference point...still classic tho
- Has thanked: 83 times
- Been thanked: 76 times
Yeah, I had one, probably still have it around here somewhere...it worked great for determining motor performance when custom cutting brushes and matching springs or playing with timing. Not a scientific tool obviously but it was cheap and worked fine for what it was...
- morrisey0
- Has thanked: 87 times
- Been thanked: 1853 times
Or a better meter.juicedcoupe wrote: ↑Fri May 13, 2022 8:50 pm Apparently, the cheap Kobalt DVM that I bought doesn't range very well, so I had to use my Fluke. Or at least, I might need to learn how to use a cheap meter.
I had one of these at one point in time, but never got into using it. Finally sold it off on the bay. Pretty sure I tried to sell it here pretty cheap with no interest.
- juicedcoupe
For me, it's just something else to amuse myself with. I like building and tinkering with stuff, and this fits perfectly.
Let's be honest. I paid $50 for it and it came with two motors. Even if I never touch it again, I'm not out much.
- 961 Views
Last post by juicedcoupe
- 1115 Views
Last post by Lastplace
- 6808 Views
Last post by RC10superfan
- 870 Views
Last post by Halgar
- 397 Views
Last post by soniccj5
- 1155 Views
Last post by hugger19
- 2185 Views
Last post by marty slater
- 730 Views
Last post by Lowgear
