Reedy DS Racing Motor ?
- Has thanked: 63 times
- Been thanked: 21 times
I picked up this Reedy DS Racing Motor recently. The guide only lists DS Spec and DS Modifieds, but this one is a tabbed stock can with bushings. It's stamped ROAR 96.
I can't find much information on the web, and was hoping someone here might have some background on it.
I did find this Reedy 1998 catalog at OldRC that indicates the DS Racing motors are budget modified with adjustable timing and bearings, so the one I have is related but different.
http://oldrc.com/download/reedy-catalog-1998.pdf
Thanks in advance
Thanks in advance
- KidAgain
- Business Member
- Has thanked: 513 times
- Been thanked: 431 times
Re: Reedy DS Racing Motor ?
I’ve seen a few and have a couple but never with the red top or purple heat sinks they’re usually silver along with bearings.
- Lowgear
- Has thanked: 121 times
- Been thanked: 795 times
I'll take a wild guess that it's been Frankenstein'd with bushings, and an endbell from a different motor. The armature could be from something else as well, and they just used the DS can.
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
You can see the dimple in the tab, where it was re-pressed.
The purple heatsinks look like the ones on my GM motors.
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Could be part Firehawk.
Thanks for the feedback!
I assumed the purple heat sinks were aftermarket.
Nice work juicedcoupe spotting that almost invisible detail!!
I took a closer look and there's definitely a mark on the tabs so it seems possible the endbell was replaced -- but the marks look really clean (a nice flat line) like I would imagine a factory assembly would produce using a jig. Do individuals use jigs to break open and reassemble motors??? If it's a Frankenstein it was done very cleanly as there's no damage in the area from opening it up or reassembly and I'd be impressed -- see better pics below.
I also looked at another stock motor I have (Reedy Rage 24) that I'm pretty confident has not been altered and see a similar mark at the top of the one tab not covered by the label. I noticed similar marks on a couple other stock motors I have lying around -- I never noticed those marks before. I'm not concerned either way as I like the color scheme with label and end bell
, but it's very interesting detective work nonetheless!
Brian
Yes -- that's what I expect the modified would normally look like.
juicedcoupe wrote: ↑Tue May 28, 2024 10:38 pm You can see the dimple in the tab, where it was re-pressed.
Brian
Good call!!
I found closeup pictures in an auction listing and the Firehawk endbell appears to be pretty much same color and exactly same design. Also the steel can is the same color and the front and sides have same pattern of vent holes and markings. It looks like it could be the Firehawk motor with a "DS Racing" label -- perhaps they made that combination as a transition.
I think I can see the same marks on the tab in the Firehawk photo also
- 2025 Views
Last post by NomadRacer
- 666 Views
Last post by Kayne
- 937 Views
Last post by V12
- 319 Views
Last post by Dangeruss
- 766 Views
Last post by Jirka
- 2222 Views
Last post by Daddeo
- 2485 Views
Last post by Bormac
- 731 Views
Last post by j.costick
