Has thanked: 1711 times
Been thanked: 1135 times
Sabba wrote:Hello tomolupus
incredible that you found or remembered this advertising.
Great thanks for that, because I really searched for, but couldn't find it.
Only in an actual american ebay-auction I found yesterday the same combination of front and rear axle called as an Associated but I couldn't believe that.
Now I have a pretty good info, thanks a lot.
Greetings
RF
Great work by tomoplus, I knew I recognised it, but couldn't quite remember why... I used to have one of these, new built... here's a picture:
Sold now... but definitely a CX12.
klavy69
Moderator
Has thanked: 634 times
Been thanked: 294 times
Post by klavy69 »
works92 wrote:the front shocks (maybe duratrax?):
Phil, these shocks look to be traxxas.
works92
Has thanked: 85 times
Been thanked: 32 times
Post by works92 »
Thank's to you klavy69 !
Still, the carbon parts (which I suppose are CML production )
The center shafts and front diff pulley (I bet on Tomy parts)
and the bearing steering (which seems to be a GPM one)
works92 wrote:Still, the carbon parts (which I suppose are CML production )
I don't know for a fact, but the weave in the carbon parts remind me of some FibreLyte Cat 2000 EC parts I used to have.... the chassis looks a *bit* like the Yok 870C chassis http://www.fibre-lyte.co.uk/fl/cars/yokomo/870c.html, and the front shock tower looks like a YZ10 Works part (http://www.fibre-lyte.co.uk/fl/cars/yokomo/yz10works.html, part WORKS03.... albeit both with slightly different holes.
naushad
Post by naushad »
I had a works '93 car which I think had those arms too! They had kyosho optima hubs.
DennisM wrote:
works92 wrote:Hi all,
I need your help to identify the origins of parts fitted a Yokomo Works91 that i purchase recently.
the front A-arms:
Phil.
I´ve got a set of the front arms - They were in a bag with a headercard from MMS.
IIRC, also referred to as "Drescher" arms
http://www.rc10talk.com/download/file.php?id=84871&mode=view
naushad
Post by naushad »
Second lot are definitely kyosho...maybe from their more budget range of buggies.
I would say last lot do look like schumey, maybe from a cougar?
R Cane wrote:Help ID'ing these shocks?
all aluminum, a spring inside the cap
have a peg on the shock body and adjustable notches for spring spacing
I didn't even see the slight yellow/orange tint on the bodies until I looked at the pictures, so maybe these are color stripped...
EvolutionRevolution
Has thanked: 17 times
Been thanked: 34 times
Post by EvolutionRevolution »
works92 wrote:
the front hubs are RPM, but what about the C-hubs, and did RPM really do this for the works91 or is this for another car ?
C-hubs look like Kyosho Optima to me.
Chassis parts, Fibre Lyte?
alien3t
Post by alien3t »
yokomo did make a c hub this style, used a kingpin I think,
Jirka
Has thanked: 31 times
Been thanked: 24 times
Post by Jirka »
Optima C-Hubs and Optima steering blocks or compatibles should be used with those Drescher arms in Yokomo.
Jirka
works92
Post by works92 »
Thank you for all those informations guys, I know a lot better now on my new buy.
If it could help to identify the carbon parts, the chassis got plies of fiber glass or kevlar in is middle ....
prp
Been thanked: 13 times
Post by prp »
For works 92 parts
the front diff:
Pulley in tufnol from SRM Racing/RW Racing
the center shaft:
Spur gear adaptator from SRM Racing/RW Racing
works92
Post by works92 »
Merci Pierre !
Au top, comme d'hab.
tomolupus
Post by tomolupus »
Greetings
RF
Good info there, the name LEE'S ENTERPRISES on the manual.
And more here
http://www.rc10talk.com/viewtopic.php?f=33&t=27413
RC10resto
Has thanked: 1458 times
Been thanked: 548 times
Post by RC10resto »
1/10 Lexan body, wing and undertray with green overspray film - what car is it for :?:
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
RC10resto wrote:1/10 Lexan body, wing and undertray with green overspray film - what car is it for :?:
looks like Tomy to me
Return to “Identifications”
