MIP tranny with stock splipper ???
General info, Q&A.
saucisse
Post by saucisse »
Do you need a special slipper unit to fit the MIP tranny? :oops:
Was looking in the manual and it's pointing the stock slipper unit but it don't fit on the MIP shaft....the shaft diameter seems to be a bit too big....
Also any of you here upgraded with a losi hydra-drive?
Thanks !
I don't suffer from insanity, I enjoy every minute of it!!
shodog
Been thanked: 91 times
Re: MIP tranny with stock splipper ???
Post by shodog »
I have not seen a standard slipper for the MIP because if you needed slip you could leave the ball diff a bit loose. MIP did however have a slipper shaft that allowed the top gear to slip on the shaft and it was adjustable.
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Post by Asso_man! »
and the Losi Hydra-drive won't fit. I've never seen an adaptator shaft...
Come and visit the stable
saucisse
Post by saucisse »
Ok....but what do I use to fit the stock spur gear on the shaft? In the archive section, I can barely see a part # for what seems to look like some kind of adapter...looks like # sp7 or something.
Anyone got this part??
shodog
Post by shodog »
Let me check, I may have some of those adapters
