New member looking for help
I have a RC10 with a 6 gear tranny that needs new idler gears. Is there a source for these? They were part #6613. If I cannot fix this tranny then is a stealth tranny a bolt in replacement? Are all stealth trannys the same? What about the newer ones for todays T4's...will they bolt in?
Thanks
Thanks
- Has thanked: 33 times
- Been thanked: 1216 times
Re: New member looking for help
tower has the idlers............
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2795&P=SM
the first gen. stealth (2.25) is a drop in replacement for a B or C stamped chassis. if yours is an A stamp, you'll need to drill 4 new holes to mount the trans to the chassis. any of the other stealths (b2/b3/t3, t2, b4/t4), would need quite a bit of modifications to the car to make it work.
welcome to the board, by the way.
- rcflyer1984
scr8p is right. Tower has the idler gears and your LHS may have some too. I know the one by me has atleast 15 pair of them. One in a while on ebay you can find a pair Of Race Master steel idler gears. I put a set in mine back in 91 and have yet to tear them up.
Tim
Tim
- Erich Reichert
you dont' "need" this but it makes life a lot easier for drilling for the stealth...
http://cgi.ebay.com/Vintage-associated-RC10-MOTOR-DRILL-plate-w-drill-RC-10_W0QQitemZ290201390095QQihZ019QQcategoryZ44017QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Where was that a few weeks ago...my stealth is just a little co ck eyed in my chassis....and I did measure twice and drill onceErich Reichert wrote:you dont' "need" this but it makes life a lot easier for drilling for the stealth...
- Erich Reichert
LOL i see it got picked up... there were actually a cople of them on ebay this week. I still have the one that came with my first stealth tranny I ever bought... one fo the most priceless tools i have
- Jeep-Power
- Has thanked: 55 times
- Been thanked: 47 times
rcflyer1984 wrote: One in a while on ebay you can find a pair Of Race Master steel idler gears. I put a set in mine back in 91 and have yet to tear them up.
Tim
diggin this up--
anyone have a lead on a set of those steel idlers for a 6 gear, please?
I have a set I got back in the day, but they are getting worn. I don't know how ling they'll hold up to a brushless setup.
- Been thanked: 498 times
I might be wrong, but i think i recall someone saying you could grind off a set of outdrives, and use them for idler gears, say if you have a set that is all mangled on the bone drives, cut, chop, grind, etc, so that the it's just a flat gear, and you are set.
- Jeep-Power
oh sweet!-- didn't even think of it. I'm gonna check that out. Thanks!
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
idler and outdrive are both 22 tooth gears. if anyone has a link to more info on this please post it up.
- 1171 Views
Last post by vintagercer
- 1104 Views
Last post by NomadRacer
- 19 Replies
- 2512 Views
Last post by Kevster
- 939 Views
Last post by SONYtec
- 836 Views
Last post by 5699
- 25 Replies
- 3293 Views
Last post by GJW
- 924 Views
Last post by matt1ptkn
- 474 Views
Last post by treehugger
