Buggy steering servo position
Back in my much younger days I picked up a gold chassis rc10 that the previous owner had converted to a truck. The truggy has the steering system in the non stock location allowing the steering linkage to be perpendicular to the steering arm.
This means that over the 20+ years I have owned it, the battery has been misplaced. I used to jam it sideways into the frame but that caused wire damage. Right now it has a wood riser and velcro which works poorly at best.
I have a 3d printer and the ability to put it back but before I do, doesn't having the steering servo offset like that affect your turning radius and/or responsiveness?
- TRX-1-3
- Has thanked: 2066 times
- Been thanked: 992 times
Re: Buggy steering servo position
While not very familiar with the particulars...if it's just a question of trading a 90° for a 90° arrangement. I think the servo capabilities would be the only limiting/enhancing factor.
- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
Rslaback
You might try an Onyx S25 servo, S22.99.
Plastic gear and bushings.
Never tried one but cheap.
Not a lot of torque, 91 oz-in (6.6 kg-cm) @ 6.0V, but should fit more easily in the front OEM position.
Other options
Futaba s148
Savox sc0254
Reedy 0712mg
You may also want to consider replacing the dual servo saver bell cranks, as they will induce a lot of free play in the steering.
These older servo saver bell cranks are often cracked, broken and sloppy.
GoMachV, a member here, usually has replacements for car and truck.
Turning radius and/or responsiveness are probably more affected by choice of servo and the position of the ball studs on the servo arm and bell crank.
Chuck
Other options
Futaba s148
Savox sc0254
Reedy 0712mg
Chuck
- morrisey0
- Has thanked: 87 times
- Been thanked: 1853 times
I have this little setup in a couple of mine. The servo is also about 90oz-in, metal gear, ball bearings, and $19. If you want to go serious bashing, you probably want something a little more powerful, especially if you are keeping it a truck. If you are interested, I can send you the .stl files and you can print yourself. The servo mount and battery tray are both printed.
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
This is my truck conversion. It uses a metal gear, standard size servo. That is the GT/DS servo saver.
The nose plate is setup in the long wheelbase format, which requires longer nose tubes.
In long wheelbase format, a standard servo can be mounted in the original holes without spacers. The front servo post will require a little clearance. I wouldn't modify original RC10 posts but don't mind grinding a set of $3 Traxxas mounts.
Someone mentioned the Onyx S25, mini servo. It does fit the original holes for a mini servo without modification. However, it looks a little frail for use in a 1/10 truck.
Those plastic gears can't be very big. It is even thinner than a older Futaba S132, mini servo.
And downright tiny compared to a standard servo.
- Been thanked: 46 times
"Low-Profile" servos as used in modern touring cars can also be a good idea.
RC10 collection in Switzerland: Original, Classic (ReRe), "Plastic" (homemade milled white cahssis), CE, Graphite-Andys, TeamCar, WorldsCar, WorldsCar ReRe, "CouldHaveBeen" (homemade similar to "RPM"), B3, 3x B4, 2x B5
- 3368 Views
Last post by coxbros1
- 733 Views
Last post by DHC6
- 1093 Views
Last post by Johnboy72
- 1407 Views
Last post by Chewbacca
- 868 Views
Last post by fiveonomo
- 858 Views
Last post by filzemail
- 1017 Views
Last post by XLR8
- 2416 Views
Last post by yellowdatsun
