Kyosho ATV Quad Rider
Dangeruss
Has thanked: 425 times
Been thanked: 1410 times
Post by Dangeruss »
In 1997 Kyosho unveiled a new vehicle to the R/C hobby, the 1/4 scale 2wd Nitro powered ATV Quad Rider. Replicating full size racing quad runners in quarter scale the Quad Rider utilized a combination of off the shelf parts and model specific components to create a very faithful model. Constructed primarily from fiber reinforced plastic the chassis was comprised of three separate assemblies, the molded front frame set held the entire front suspension which used the lower a-rms, hubs, and knuckle assembly from Kyosho's Nitro Pro ST racing stadium truck with adjustable metal camber links and a pair of neon green plastic body oil filled coilver shocks with spring tension clips and aluminum caps. The steering system consisted of adjustable metal tie rods leading to a Kimbrough servo saver attached to the vertically mounted servo that was tucked out of sight behind a pair of closeout panels. The center frame set was a flat aluminum plate that acted as a heat dissipating motor mount and lower skid plate while the molded plastic rear frame set which attached the front and center frames into a single triangulated chassis served as a mounting point for the swing arm supported solid axle rear suspension. A single oil-filled plastic body coilover shock with adjustable spring collar provided dampening to the ball differential equipped rigid axle assembly, itself driven by a miniature roller style chain that connected to the motor via a pinion and spur primary drive. Kicking up the dirt was single piece 2.2 wheels wrapped in 540/100/62 Pin Spike rear tires and 510/100/62 Ribbed front tires pulled from the Nitro Pro ST parts bin. A clear lexan body, articulating hard plastic rider, GS12S-CR .12 motor, muffler and complete set of bushings were included in the partially assembled kit, sold less electronics and radio. An electric version, the Quad Rider EV, was released in 1999:
2-page ad combined into a single poster:
HS-YZ250
Has thanked: 178 times
Been thanked: 155 times
Re: Kyosho ATV Quad Rider
Post by HS-YZ250 »
Now for the important question: is it styled after a Suzuki Quadracer or a Honda TRX250R?
Losi LXT (JRX-T Conversion)
Losi JRX Pro SE
Kyosho Rocky
Parts-Car-to-Runner Kyosho Rocky
Yokomo YZ10 WCS '95 Pavidis
RJ Speed Spec10 "Chew Toy Mk1"
Redcat Lightning STK "Chew Toy Mk 2"
Kyosho Lazer ZX, ZX-R, ZX-RR
Has thanked: 2605 times
Been thanked: 2978 times
When I first saw this I read it as Kyosho ATV Quad Dangerous. Oops :mrgreen:
Dangeruss
Post by Dangeruss »
HS-YZ250 wrote: Tue Apr 01, 2025 7:59 pm Now for the important question: is it styled after a Suzuki Quadracer or a Honda TRX250R?
Quadracer... Quad Rider... both yellow and blue.... hmmm... 🤔
Frankentruck wrote: Tue Apr 01, 2025 8:01 pm When I first saw this I read it as Kyosho ATV Quad Dangerous. Oops :mrgreen:
Ha... when speed reading goes awry. :lol:
HS-YZ250
Post by HS-YZ250 »
Dangeruss wrote: Tue Apr 01, 2025 10:21 pm Quadracer... Quad Rider... both yellow and blue.... hmmm... 🤔
While I always raced the Honda, and it was objectively the better quad, I now see from your scans the Kyosho has the cutout in the rear fender for the LT's rear acting kick starter. The Fourtrax's goes forward. So I'd have to agree.
Both quads were long out of production in 1997, last years were 89 for the Fourtrax and 92 for the LT, so I'm surprised the kit was introduced that late.
*EDIT* well, both sides have that same feature, so maybe not.
Losi JRX Pro SE
Kyosho Rocky
Dangeruss
Post by Dangeruss »
HS-YZ250 wrote: Wed Apr 02, 2025 9:57 am While I always raced the Honda, and it was objectively the better quad, I now see from your scans the Kyosho has the cutout in the rear fender for the LT's rear acting kick starter. The Fourtrax's goes forward. So I'd have to agree.
Then comes 1999 and the Quad Rider EV in Yamaha blue and the whole conversation starts over again. :lol:
HS-YZ250
Post by HS-YZ250 »
Dangeruss wrote: Thu Apr 03, 2025 4:14 am Then comes 1999 and the Quad Rider EV in Yamaha blue and the whole conversation starts over again. :lol:
That one would be a little more vague. Yamaha's Banshee is pretty distinct.
Losi JRX Pro SE
Kyosho Rocky
Dangeruss
Post by Dangeruss »
HS-YZ250 wrote: Thu Apr 03, 2025 10:37 am That one would be a little more vague. Yamaha's Banshee is pretty distinct.
Talk about a face only a mother could love... I was thinking Warrior... ish... if you squint.
