I'd like to load up on some replacement shock o-rings and was curious if there are aftermarket options that you folks like to run vs. the stock orange? Are the re-release shafts 3mm in diameter?
Thanks!
RC10 Re-release shock seal options
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2094 times
Re: RC10 Re-release shock seal options
They are 1/8" shafts, but stille use the same "006" size o ring. I have a large bag of 006 sized silicone o rings that I use on everything.
- Has thanked: 1243 times
- Been thanked: 639 times
most all 1/10th shock o-rings works.
I use the traxxas 2362 rebuild kit o-rings. Associated makes low friction x-rings. I also use these Avid X-rings
- Has thanked: 26 times
- Been thanked: 4 times
Got it - so even the x-rings for the modern AE race buggies are still the same size/fit well in the re-release RC10's? Good to know! Thanks for the suggestions.
- 458 Views
Last post by TokyoProf
- 1545 Views
Last post by Proc1973
- 1004 Views
Last post by JosephS
- 1066 Views
- 986 Views
Last post by RC104ever
- 868 Views
Last post by BigPun76
- 2489 Views
Last post by rcnj
- 1583 Views
Last post by Mr. ED
