Remove rust without damaging finish
fakiee
Post by fakiee »
kaiser
Re: Remove rust without damaging finish
Post by kaiser »
royal jelly?
EDIT:
naval jelly lol
Has thanked: 356 times
Been thanked: 470 times
Hand cleaner ( like goop ) without pumice. Coat them and let them sit for a day or so, wipe off and its done.
reign79
Post by reign79 »
CLR calcium lime and rust remover works ok if you let it sit for a couple of days.
Ryan
fakiee
Post by fakiee »
Charlie don't surf wrote:Hand cleaner ( like goop ) without pumice. Coat them and let them sit for a day or so, wipe off and its done.
Like Swarfega? I only have the heavy duty stuff, might give it a go anyway. Is the normal stuff good for nylon parts (white)?
Appreciate the help chaps :D
fakiee
Post by fakiee »
Lowgear
Has thanked: 121 times
Been thanked: 795 times
Post by Lowgear »
I think what you were after was rust converter instead of remover. The kind that turns rust into a black finish.
fakiee
Post by fakiee »
steve
Post by steve »
I just finished redoing some tie rod and dog bones. I put up some pic soon. Sand then clean, pick up some gun blueing and some past wax (minwax) . I did 2 coats of blueing , let dry over night then put a good coat of past wax and let dry 15-20 min. rub out with soft cloth and add a 2nd coat of wax and let dry, rub that out and your done. the wax will mellow out the blueing and help stop rust from comming back
steve
fakiee wrote:
Lowgear wrote:I think what you were after was rust converter instead of remover. The kind that turns rust into a black finish.
Yep, thats sounds like it could have worked :wink:
Oh well too late now. Still, I think the end result looks ok:
Want to re black them? Take a torch and heat them to cherry red- drop them in transmission ATF fluid- instant hardened steel, and black to boot.
Has thanked: 3699 times
Been thanked: 1980 times
Any risk of deformation or fire when they hit the fluid. I forgot, but I actually have a set of those rods that look a bit rough.
Just some smoke-
bigdavevw
Post by bigdavevw »
Oxalic Acid removes rust without damaging the finnish 8)
aconsola
Post by aconsola »
bigdavevw wrote:Oxalic Acid removes rust without damaging the finnish 8)
I've had good results with the oxalic acid available as barkeepers friend:
http://www.barkeepersfriend.com/
flipwils11
Been thanked: 19 times
Post by flipwils11 »
Evaporust, Harbor Freight sells it. The stuff works miracles on rusty full size car parts.
Users browsing this forum: User avatarDirtburner, User avatarjuicedcoupe and 3 guests
