Vintage Style Wheels for 2.2 Tires
Hi Everyone!
I am working on restoring my old A-stamp RC-10, and I was kind of thinking of doing some racing. I know there are a few options out there to do 2.2 inch wheels and tires, but I was hoping I could get something a little more vintage-looking. The JC wheels don't do it for me, unfortunately, and the JConcepts stuff seems rather limited. I was hoping that someone out there made something similar to this, but in plastic or nylon.
http://www.ebay.com/itm/231333630658?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Does anyone know of anything like what I want? Basically a 2.2 inch wheel set that looks vintage correct and that won't cost my first child's college tuition.
Thanks!
Thanks!
Re: Vintage Style Wheels for 2.2 Tires
you are stuck with dish wheels or the jconcepts rulux, or the jcrc racing 5 spokes. What vintage style wheels are you looking for? The jelly bean style you have shown were never in 2.2 other than modern alloy from that seller. Most racers went to flat dish to keep dirt out and keep it lightweight so wheel style for rc-10's is basically boring.
the only other option you might have, but it requires some work, are the HPI super star wheels that are modified.
http://www.rc10talk.com/viewtopic.php?f=38&t=20904&hilit=hpi+super+star
if you like this style:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJJ72
you can get them front and rears and adapt them to rc10 axles using hpi adapters
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXN057&P=7
HPI sells a front set that are bearing spacers to adapt from 11mm OD.
I'm not sure the offset is right for the rear wheels however. front are probably fine.
Ok, I really like those Traxxas wheels. I may have to experiment with them. Has anyone tired them?
they have been around for a long time. the fronts should fit no problem with the bearing spacers. the rear, the offset would need to be checked, but I think they are close. Now that I think about this, I'm not sure they are hex drive, they might be pin drive. in that case, a 3/16" axle would be better on the rear, or you need to modify them for a rc10 1/4" taper axle.
- Has thanked: 1129 times
- Been thanked: 3917 times
I designed a set of 2.2 jelly beans with plans of 3d printing them but they ended up being too expensive. Might do them anyway for the cool factor but need to save funds.
Ill make them available for purchase (shapeways) but need to verify sizing first...everything I have is old so Ive not taken measurements on modern wheels.
-Mike
RC10T | Kyosho Lazer ZX - 55mph | Mid Motor RC10 Pan Car Conversion - 72mph | OIN RC10 spare/used parts build - 69mph | 4x4 MonsterT build
86 ascMcLaren Capri 5.0 | 86 Mustang SVO
mikemartinelli.com
My Shapeways Stuff
mikemartinelli.com
My Shapeways Stuff
- 553 Views
Last post by cyberded
- 2064 Views
Last post by bats
- 806 Views
Last post by tallpaul
- 2090 Views
Last post by XjRob98
- 1231 Views
- 4196 Views
Last post by XLR8
- 1404 Views
- 1332 Views
Last post by Lonestar
