RC10 DS Classic - Build
Everything pertaining to the RC10DS re-release.
GreenBar0n
Has thanked: 1270 times
Been thanked: 860 times
Post by GreenBar0n »
I'll be fitting the Stock body on this chassis with the black and green boxart. Will also fit a couple custom bodies to this chassis, and may get another DS at some point for those.
Time to get started.
GreenBar0n
Re: RC10 DS Classic - Build
The instruction manual comes with a 1:1 parts fold-out, this should've been how all of them were done.
A Fast Eddy's bearing kit will be here tomorrow, going to get as far as I can without them.
https://www.fasteddybearings.com/team-associated-rc10ds-classic-kit-sealed-bearing-kit/
Dustydrone
Has thanked: 529 times
Been thanked: 110 times
Post by Dustydrone »
GreenBar0n wrote: Wed Aug 07, 2024 3:06 pm Image
I'm looking forward to this build!🍿😎
GreenBar0n
In the manual the wheels and tires are Bag H, found on the second to last page. Apologies for doing this out of order, it's a habit I can't break.
https://img2.associatedelectrics.com/pdf/cars_and_trucks/RC10DS/Classic_Kit/RC10DS-Vintage-Manual-2024-V1.pdf
The front tires are really thin and pliable, like nothing I've seen before. The traction these must offer is going to be incredible!
Wheels look good without the caps too.
DS wheels next to HPI 12mm hex wheel, the DS wheels are a bit smaller.
Going to order some ASC1697 Tire Adhesive.
https://www.amainhobbies.com/team-associated-factory-team-ca-glue-tire-adhesive-mediumthin-asc1697/p1550641
Will begin at Step1 in the manual now, thanks for humoring me. :D
GreenBar0n
I took a look at the paint required for the DS boxart. The black would be Tamiya PS-5, but the green is a bit harder to figure out.
To me it looks most like Tamiya PS-21 Park Green.
PS-22 Racing Green seems too dark.
Going to order PS-21 Park Green, unless anyone knows the exact color it should be.
MarkyDents
Has thanked: 1809 times
Been thanked: 643 times
Post by MarkyDents »
So strange to see that rubber say Team Associated and not Proline :shock:
Hey Cru ! Go balls out 8)
GreenBar0n
Taking a break, about done with Bag A.
Was not expecting the foam dust covers, like the ones that originally came with my '96 CE and '97 GT kits.
GreenBar0n
Steering plate finished.
The ball cups had to have the sprue trimmed off of them still. Used the old AE kit tools to build the turnbuckles, no marks left anywhere.
Ran into a problem, was missing (2) ball studs from Bag A, tore the place apart looking for them.
The problem is in the manual, they tell you to add the ball studs for the front sway bar out of Bag A:
Once you get to the steering assembly, you're missing (2) ball studs from Bag A, because they are in the front arms for the sway bar. In Bag B, which contains the sway bar, are the (2) missing ball studs:
Hope that saves someone else some wasted time and grief.
Other issue with the manual, in the BHCS screw section on the cover flap, the 3/8" and 5/16" BHCS 1:1 size chart are missing:
GreenBar0n
Left the front body posts off for now.
Bags A and B are done. Don't have a steering servo picked out just yet and Bag C is all about it. Bearings will be here tomorrow, need to decide on vintage style electronics, or modern.
GreenBar0n
GreenBar0n
Bag C is for the steering servo, and battery cup. My servo won't be here for a bit, so I'll leave Bag C sealed for now.
Time to get the rear half built.
That's a big D bag.
Comes with three different sets of blocks for rear toe in, 0°, 1.5°, and 3°. Not sure which to choose yet.
Going to try to finish the chassis tonight.
After reading this:
https://rcguided.com/rc-rear-toe-tuning-simplified/
I'm going with the 1.5° toe-blocks.
GreenBar0n
Rear half.
This DS manual is sabotage at this point. How did this happen, where the ball stud busted out of the backside?
The manual shows this picture, but in the 1:1 size chart on the cover flap, the ball studs are not available to measure.
The rear sway bar is still sealed when you open Bag D, there are (4) long ball studs in Bag D. I now have two extra holes in my arms because of this.
Sway bar ball studs are in the sway bar bags, do not use any other ball stud for that location, ignore the manual!
Next manual problem, the rear bulkhead ball studs. Can anyone tell me exactly where the camber tie-rod ball studs go according to this pic?
Here's where I had to guess they went, this is the rear of the bulkhead:
If a socket won't fit on here, are the camber tie-rods going to?
Will look at the vintage DS manual to see if it makes any sense on the rear bulkhead ball studs. What is it with this model and ball studs??
GreenBar0n
Vintage manual sorted it out.
Going to keep the vintage manual close by from now on.
https://www.manualslib.com/manual/2176101/Associated-Electrics-Team-Associated-Rc10-Ds-Dual-Sport.html
Been thanked: 3917 times
unfortunately AE forgot about thew Worlds holes on the new bulkheads. Best alternative is the inside under the wing tube holes where you have them. It was always impossible to get a driver in there haha. A tamiya took just sqeaks by
Has thanked: 268 times
Been thanked: 2094 times
GoMachV wrote: Thu Aug 08, 2024 9:33 pm It was always impossible to get a driver in there haha.
Swap the ball studs for some Custom Works versions. They have the 3/16 hex shoulder and 1/16 internal hex, still 4-40 threads.
Return to “Associated On-Road Re-Release Forum”
