Exactly, it acts like it should just not putting out power to the motor. I got this speed control along with a bunch of other parts so if it's nuked it won't be a big loss. I'll just go with a new Novak brushless system if it can't be fixed. I could also start hunting for another one since these are fairly common. I'll have to think on it. I've got lots to do on this project anyway so it's really not much of a setback. I'll probably start working on the wing and mounts for the second body.gomachv wrote:So did you say the light flashes when you give it throttle? Like the light knows its getting a signal but not sending power to the motor?
Could be a lot of things but it wouldn't hurt to throw a voltmeter on the motor leads and see what's up. The setup on those older speed controls was tricky and it may just be that simple
RC10L Runner ****FINISHED****
- PlastiZapCA+
Re: RC10L Runner
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: RC10L Runner
Man if the lights are reacting to the trigger but no output it's either dead or the motor is dead. You sure you got the endbell clocked correctly, right? If its the right degree off it may not run. Probably fried esc tho.
- PlastiZapCA+
Re: RC10L Runner
markbt73 wrote:Man, seeing those individual cells in the chassis next to that big fuse brings back memories... gotta get back going on my 10L. Got sidetracked as usual.
Too bad about the T4. Hope you can get it sorted out. It sure looks the part.
Your Mustang will look sweet painted up.
I'll save the case from this T-4 and swap out the guts with another functional T-4 if I can't get it going. The case looks like new.
- PlastiZapCA+
Re: RC10L Runner
I ran the motor up on another car and it's good. Looking like fried esc to me. Will do some more research though. I'll open up the case and see what it looks like in there.gomachv wrote:Man if the lights are reacting to the trigger but no output it's either dead or the motor is dead. You sure you got the endbell clocked correctly, right? If its the right degree off it may not run. Probably fried esc tho.
- PlastiZapCA+
Re: RC10L Runner
Fixed it! Replaced the faulty communication cable and it cranked right up.
Check it out.
[youtube]Xfqr5q7zWnw[/youtube]
Check it out.
- PlastiZapCA+
Re: RC10L Runner
Another project that sat for way too long. I decided to get serious with it in the end and made some performance upgrades. It's no longer a junk yard dog.
This got her moving!
Other than the soldered on motor wires this one was new. I just lubed the bearings and connected it to my setup.
I also added a NOS HPI carbon front brace, Hyper Drive angled aluminum servo mounts and the proper Associated spacers to drop the nose down.
- LoboNYC
- Has thanked: 870 times
- Been thanked: 356 times
Re: RC10L Runner ****FINISHED****
Love the fact that you got the correct decals for the body...i used the same body but decals read "HPI RACING" instead of "SUNOCO CAMARO"
OUTSTANDING JOB!!!!
OUTSTANDING JOB!!!!
- RC10resto
- Has thanked: 1488 times
- Been thanked: 550 times
Another beauty
The rear wheels look really nice, did you cut them down or was this pair narrower
- PlastiZapCA+
Thanks man! The Sunoco decals are made by Mr. Lexan. I wish he would make some more of them.LoboNYC wrote:Love the fact that you got the correct decals for the body...i used the same body but decals read "HPI RACING" instead of "SUNOCO CAMARO"
OUTSTANDING JOB!!!!
- PlastiZapCA+
Thanks! I used 2" rears since they have an offset and then cut off the excess. They now fit a standard rear tire. Once I trim a bit off the inner front hubs they will have a nice fit too.RC10resto wrote:Another beauty![]()
- Diggley
This might be my favorite 10L....EVER!
Nice work!
Nice work!
Projects and shelfers:
- PlastiZapCA+
romulus22 wrote:Man I forgot all about this car. Looks killer. Again, fantastic work.
Thanks! It seems like the really rough ones turn out the best for me. I nearly threw this car out when I first saw it.
- PlastiZapCA+
Thanks Diggley!Diggley wrote:This might be my favorite 10L....EVER!![]()
Nice work!
- 1856 Views
Last post by DerbyDan
- 1425 Views
Last post by RedScampi
- 1585 Views
Last post by mtbkym01
- 26 Replies
- 6234 Views
Last post by nikoscfu
- 45 Replies
- 8293 Views
Last post by WC1982
- 2689 Views
Last post by klavy69
- 1534 Views
Last post by Mad Racer
- 1813 Views
Last post by cas22
