GOOD TOOL
bully
Been thanked: 6 times
GOOD TOOL
Post by bully »
Hey everyone got this for few buks from hobbyking. It is perfect for removing gears from top shafts to do rpm 2.65 trans with b4 top shaft. Also great at removing pins from driveshafts at outdrive end to replace pins for those that have removable pins that is.
Re: GOOD TOOL
Yeah, I've considered adding that tool to my toolbox...someday I will break down and buy it.
justinspeed79
Re: GOOD TOOL
Post by justinspeed79 »
Nice. Next time I make an order I'm going to get one.
MotoObscura
Has thanked: 45 times
Been thanked: 65 times
Re: GOOD TOOL
Post by MotoObscura »
What exactly is it? I mean is i meant for pulling gears? It almost looks like a chain breaker tool.
Nick DiVitto My current vintage racing lineup: Associated RC10 B2, RC10 Team Car, Losi XXT, RC10T, XX4, XFactory X5, Schumacher CAT 2000 www.moto-obscura.com My Youtube Channel
vintage AE
Has thanked: 29 times
Been thanked: 36 times
Re: GOOD TOOL
Post by vintage AE »
That's a great idea, I like it!
Been thanked: 3917 times
Re: GOOD TOOL
I have an old Parma pinion puller that's pretty similar, pretty handy
bully
Re: GOOD TOOL
Post by bully »
Yeah it is a pinion removal tool and gear puller,i thought it may work as a tool to pull the gear off the rpm top shaft because i don't have access to a press and it worked fine. A mate asked about some cvd pins for his 1/8 buggy and this tool was great at getting the pins most of the way out easily..http://www.hobbyking.com/hobbyking/store/__11447__Turnigy_Pinion_Removal_Tool.html
RC104ever
Re: GOOD TOOL
Post by RC104ever »
I must be stupid because I don't get how this works :lol: :oops:
- Chris
Lots of cars...so many cars
Re: GOOD TOOL
RC104ever wrote:I must be stupid because I don't get how this works :lol: :oops:
The same basic idea as a Pitman arm puller. Imagine you have a pinion gear or bearing stuck on a shaft. The flat bottom part of the tool slots in behind the gear or bearing. You tighten the T-handle, which presses the pointy part against the shaft and as the pressure increases, it pulls the flat part towards the pointed part, and ultimately pulls the gear/bearing off the shaft. It's much less likely to damage the gear or bearing than trying to pry it off with some other tool.
abailey21
Re: GOOD TOOL
Post by abailey21 »
not sure if it would work or not but it looks like you could use to pop off stubborn roll pins too
bully
Re: GOOD TOOL
Post by bully »
It does work for 1/8th driveshaft pins easily,better pic should explain alot...
Lowgear
Has thanked: 121 times
Been thanked: 795 times
Re: GOOD TOOL
Post by Lowgear »
A pinion/gear puller is one of those tools I've been meaning to get but never seem to. :?
RC104ever
Re: GOOD TOOL
Post by RC104ever »
Ohhhhhh, now I get it!
- Chris
Has thanked: 3699 times
Been thanked: 1980 times
Re: GOOD TOOL
That's pretty cool. It could have definitely saved me some grief trying to pull drive-pins over the years. :x
Users browsing this forum: No User AvatarDotNetDotCom.org [Bot], User avatarXLR8 and 5 guests
