Novak Atom Power Capacitor
Wazza22
Post by Wazza22 »
Hi there,
I am on the hunt for a replacement power capacitor for my Novak Atom. Should also be the same as used on the Cyclone from memory.
Would anyone know the actual specs for this particular unit? I have done some googling and can only find a reference to a part number. All the current ones for brushless controllers are different I am led to believe.
Any help appreciated!
Cheers
Been thanked: 3919 times
Re: Novak Atom Power Capacitor
From a bit of poking around, the caps are 10v 4700uf and Novak won't specify the ESR, so people are recommending that a cap rated to 105 degrees should be a low enough ESR. This fits that spec....
http://www.digikey.com/product-search/en?vendor=0&keywords=493-11294
There are plenty of others so have a look, I linked to the one that provided the spec that were provided and had the longest average life at 105 degrees. If you can find an ESR value you could narrow it down better
RichieRich
Has thanked: 39 times
Been thanked: 25 times
Post by RichieRich »
I wrote to novak a few years ago with the same question. John responded back saying they are 16v 680uF caps. The part number is 5682 if you want genuine parts or you can buy them online for cheaper.
Interesting.... But id take a Novak techs advise over the bit I searched any day! In the manual it specs a part number 5670, which doesn't come up on the Novak chart, however in a pic of a cyclone which uses the same kit it shows this...proving Richies post
tamiya
Been thanked: 9 times
Post by tamiya »
my later Cyclones came with Novak's capacitor-bank-on-a-PCB not just single cyl
Wazza22
Post by Wazza22 »
This is quite confusing indeed. I found this page on the Novak site.
http://www.teamnovak.com/products/discontinued/power_cap.html
I guess as long as the capacitor doesn't damage the speedy it should matter.
Cheers
RichieRich
For that application all you need is a regular cap. At least 12v working voltage. Higher if you are using 3s lipo or higher count nicd cells. 1000uf is probably an ideal value. Low ESR has some benefits but most standard parts now have decent ESR compared to years ago. Digikey mouser jameco many other places have these type in stock.
Wazza22
Post by Wazza22 »
Thank you all for your help, I have located some 16v 1000uf units at my local electronics store.
Cheers,
Warren
bully
Been thanked: 6 times
Post by bully »
I recently contacted Novak about the capacitors for the cyclone esc and was told the 5688 power cap is the replacement for the original one but this has recently been discontinued and they said the new triple power cap can be used also... I wanted a factory type look so I got Cpl of the 5688 to use.. The 5688 has a small pc board with the wires already soldered to it and the cyclone esc has the wires coming from the case already so I cut two lines either side of the pcb and pealed back the shrink to allow access to solder the esc wires to the board then fold back the shrink and cover the whole thing with some single cell shrink for that factory look. The pcb board does not need to be removed,it is fine to leave attached to cap... If you do much of a search you will find that they strongly recommend the use of rc specific power caps for the best performance and safety of your esc.. The esc manufacturer's don't exactly advertise the specs for their power cap they just provide basic information so it can be hard to make sense of them so if you plan on using your esc I would recommend the Novak caps only..
There is no magic in an electrolytic capacitor. Its simply there for transient load filtering. No worries on a generic replacement unless its a crappy vendor. Use japanese brands and you are good. Chemicon nichicon and panasonic are excellent choices.
Wazza22
Post by Wazza22 »
The ones I sourced are 'Suntan' brand (no joke). Chinese manufacture I suspect. I'll see how they go.
Cheers
The Novaks seem to use Samxon caps which are generally regarded as "good" in the motherboard world.
The Samxon low ESR 680uf 16v caps are about $.44 a pop here
http://www.badcaps.net/store/product_info.php?cPath=2&products_id=115
