best way to pop off ballcups?
The title says it all. Is there a certain tool that is best for this?
-Peter
-Peter
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Re: best way to pop off ballcups?
I use pliars but wrap them in paper towel first.
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
You use the smaller cut out near the middle on the AE tool multi
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAESA&P=7
- Lowgear
- Has thanked: 121 times
- Been thanked: 792 times
I've never tried it but a plastic dash trim removal tool should work well and not damage anything.
http://www.ebay.com/sch/i.html?_odkw=plastic+dash+trim+removal+tool+kit&_from=R40|R40|R40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xdash+trim+removal+tool+kit.TRS0&_nkw=dash+trim+removal+tool+kit&_sacat=0
- marlo
- Has thanked: 18 times
- Been thanked: 22 times
If its on one of mine, I remove the hinge pin. With that much play now, it makes popping off the ball cup very easy, and a damage free task. Partial disassembly of the car is needed however.
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Ballcups with a hole and ballstuds with a hex head
- limestang
- Has thanked: 100 times
- Been thanked: 249 times
Some of the ball cups are easier to release then others and can require different tools or techniques. For vintage Associated stuff I agree with marlos approach.
If your in a hurry a good running start into a hard object usually works for me, but don't get carried away and do what this guy did...
- Limestang
- Limestang
- Attachments
- Fg%20Monster%20Crash.jpg (19.08 KiB) Viewed 2046 times
- Has thanked: 1129 times
- Been thanked: 3917 times
If you're using the new glow in the dark green associated cups, all you have to do is look at it for a minute and when you turn away they pop right off.
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
I use this one - One of the best "new" tool inventions, I´ve seen.
Jaws are always parallel.
http://www.knipex.de/fileadmin/site/knipex/scripts/mediando/images/KNIPEX/Produktfotos/web/zoom/86031254k.jpg
Gone fishing
- slotcarrod
- Been thanked: 45 times
That's funny? I beat the crap out of mine on my runners and they never pop off. I make sure to snap them on square to the ball end when new. I thread the first few turns on the turn buckle by hand, pop them on the balls. Then I use the tool to adjust for correct camber and toe. Not sure why you are having these pop off so easy?gomachv wrote:If you're using the new glow in the dark green associated cups, all you have to do is look at it for a minute and when you turn away they pop right off.
Rod Littau
