UM-1 vs OT-27 centre gear
Grunger73
Post by Grunger73 »
Hi all,
I'm looking for a centre gear for my Optima. I have a UM-1 package of gears which I think was left over from an Ultima. Looking at pics of the OT-27 gear set for the Optima, the centre gear in both sets look very similar. Are they the same? Can it be used on my Optima build?
Many thanks
Been thanked: 3919 times
Re: UM-1 vs OT-27 centre gear
Yes, the same gear but packaged with different gear sets.
Grunger73
Post by Grunger73 »
GoMachV wrote:Yes, the same gear but packaged with different gear sets.
Excellent. That will save me a few bucks. Are these centre gears prone to being chewed up? I noticed that there is a special version , W0110, where the smaller gear is made of metal.
It's also metric 48p (can't recall what module they call it)
They are getting hard to find, for a decent price anyway. I don't remember chewing them up with bearings but on a bushing car they ran loose and would start to twist the teeth a little.
Grunger73
Post by Grunger73 »
GoMachV wrote:It's also metric 48p (can't recall what module they call it)
Thanks. It looks like I'll need two 4x8 mm bearings. Not sure what I can use for a spacer between them as its not included in the package
A 5x8 bushing or bearing does a good job but I always ran 4x8 flanged bearings which imo makes a lot more sense! They fit fine but I may have left out the o-ring....I don't recall for sure if it fit or if I just used a washer
Grunger73
Post by Grunger73 »
GoMachV wrote:A 5x8 bushing or bearing does a good job but I always ran 4x8 flanged bearings which imo makes a lot more sense! They fit fine but I may have left out the o-ring....I don't recall for sure if it fit or if I just used a washer
Thank you. That's very helpful. You're right. The flanged bearings do make more sense.
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Post by aip47-2008 »
Flanged is the only way to go! You'll be happy with that choice. :)
DennisM
Has thanked: 30 times
Been thanked: 62 times
Post by DennisM »
The nearest module would be .5
Gone fishing
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
I may have missed something in the conversation :oops:, but ain't early Kyosho stuff Mod .8 which is interchangeable with 32p?
Metric 48p would be either the Mod .6 or .5 that Tamiya used. Can't remember which...Tamiya used both.
Phin wrote:I may have missed something in the conversation :oops:, but ain't early Kyosho stuff Mod .8 which is interchangeable with 32p?
Yeah you missed where he asked about the W0110 racing cluster gear :mrgreen: that's the metric 48p
Phin
Post by Phin »
Grunger73
Post by Grunger73 »
For the sake of simplicity, I think I'll just stick with the original centre gear. I would hate for there to be some sort of pitch mismatch. No need for any premature wear as these gears are pretty expensive. I would like to find one of those Turbo Optima limiter gears though. I've looked on eBay but haven't seen any complete gear/shaft
DennisM
Post by DennisM »
Who´s buying the beers :D
Gone fishing
Hey Dennis, toss those aside for me :mrgreen: you can never have enough of em
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarTbot [Bot] and 4 guests
