RC10LS bearings?
olfrjf
RC10LS bearings?
Post by olfrjf »
Hi all, do you know where i can found a complete bearings set for my Rc10LS?
front wheels (4) rear pod (2)
Thanks
Olivier :wink:
Been thanked: 3917 times
Re: RC10LS bearings?
The rear pod bearings are 1/4 x 3/8 flanged. There are 4 total, two in the diff and two on the axle. The bearing number is FR168. This should make it easier to locate in your country. The front wheel bearings are 1/8 x 5/16 flanged and are a FR2-5
Hope this helps. I could send you to a few places in the USA but you should have better choices more local to you.
olfrjf
Post by olfrjf »
GoMachV wrote: Wed May 29, 2019 9:20 am The rear pod bearings are 1/4 x 3/8 flanged. There are 4 total, two in the diff and two on the axle. The bearing number is FR168. This should make it easier to locate in your country. The front wheel bearings are 1/8 x 5/16 flanged and are a FR2-5
Thanks for this GoMachV :wink:
jannickz
Post by jannickz »
Team Associated Factory Team RC10L4 / RC10L5 / RC10LSS / RC12LSS Metal Sealed Ball Bearing Set: This official Team Associated kit is specifically designed for your RC10LS and includes all the bearings you need (typically 9pcs). You can find it online at retailers like Bonanza, TBS Bearings and J-M Supplies.
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
Just be careful depending on what front wheels you have may require flanged or unflanged front bearings.
