Small axle pin removal
Scottzone
Post by Scottzone »
Any advice on how to remove this small axle pin? The other side was tight but came right out. This side is stuck. I have tried oiling it, but still not budging. This is a 2x10 split roll pin in the rear of an Outlaw Rampage Pro.
Has thanked: 3481 times
Been thanked: 1909 times
Re: Small axle pin removal
I use needle nose pliers and kinda angle it so you have one side on the end of the pin and the other against the threads. If you're careful it doesn't cause any issues. Once it budges, it usually comes out fairly easy. Below is a fancier solution.
https://www.rc10talk.com/viewtopic.php?t=50411
1911Colt
Has thanked: 1708 times
Been thanked: 809 times
Post by 1911Colt »
EDIT: someone smart was typing at the same time as I was writing this. Sorry Thumbs!
Temporary answer until someone smart chimes in...
If your friends are shooters, someone in the group will have a set of small brass punches and experience removing pins. :D Put nuts on the axle to protect the threads and tap it out. Sit the car in the normal position with the pin straight up, support the axle on both sides of the pin, and drive it out.
1911Colt wrote: Mon Apr 28, 2025 11:57 am EDIT: someone smart was typing at the same time as I was writing this. Sorry Thumbs!
If someone smart was typing, there must have been someone else involved! :mrgreen:
1911Colt
Post by 1911Colt »
THEYTOOKMYTHUMB wrote: Mon Apr 28, 2025 12:11 pm
:lol:
JosephS
Has thanked: 1209 times
Been thanked: 610 times
Post by JosephS »
I've used a needle nose pliers to squeeze the sides of the pin so it compresses. From there I try and push the pin out. Sometimes just a few hard compressions on each side is all that's needed to loosen up the pin.
Scottzone
Post by Scottzone »
Thanks everyone, I was able to wiggle it out with needle nose. Definitely need a new pin now.
Any suggestions on safely removing the 4.5 ball ends on this thing? I already broke one trying to use a screwdriver to pry it off.
JosephS
Post by JosephS »
Scottzone wrote: Mon Apr 28, 2025 4:02 pm Thanks everyone, I was able to wiggle it out with needle nose. Definitely need a new pin now.
2 pairs of pliers and twist the parts in opposite directions.
Brendan2904
Has thanked: 246 times
Been thanked: 245 times
Post by Brendan2904 »
The jaws of channel locks are offset perfectly so that you can push with one side of the jaws and stabilize it with the other until it is flush with the axle on one side and then you can pull it out with the channel locks like a pliers after that.
limestang
Has thanked: 95 times
Been thanked: 249 times
Post by limestang »
I recommend setting the axle on a block of wood and then tap it out with a hammer and punch. Light taps will do the trick.
- limestang
Brendan2904
Channel Locks like I said……
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarMojeek [Bot] and 4 guests
