What belt drive trans is this?
Hi All,
Can you please help identify this belt drive transmission that came with a Grapite RC10 I picked up? There is no branding at all on it.
Thanks
Thanks
- Attachments
- trans2.jpg (29.14 KiB) Viewed 2080 times
- trans4.jpg (24.38 KiB) Viewed 2080 times
- trans1.jpg (28.44 KiB) Viewed 2080 times
- Has thanked: 1129 times
- Been thanked: 3917 times
Re: What belt drive trans is this?
Thanks for that.
Looks like they're still available to buy from A & L?
http://vintageteamaandl.com/lethalweapon.htm
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Is there any advantage to belt drive transmissions aside from being quieter? Although cool they seem like a power robbing device to me. What am I missing?
- Has thanked: 7 times
- Been thanked: 42 times
Once they're broken in they're pretty good, but still less efficient than a 3 gear transmission. That being said, with brushless motors and LiPo's, it's become a non-issue.
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
Belts are more efficient than gears but are more expensive and add a little more complexity in design because belts are finicky about getting the tension right.
They're still used often in modern RC cars running brushless + lipo......just more so in on-road touring cars than in off-road buggies.
Plus, manufacturers don't really go out on limbs and make zany aftermarket parts for RCs anymore.
- DMAT
- Been thanked: 4 times
zany aftermarket parts.....what is a kit to convert a 1/10 4x4 slash into a 1/8 buggy called then? or is this a thing now?
- Bottom Feeder
- Has thanked: 13 times
- Been thanked: 25 times
Ah, the good old days.Phin wrote:Plus, manufacturers don't really go out on limbs and make zany aftermarket parts for RCs anymore.
I used to design belt and chain systems up to 2200 hp for mud pump applications in oil drilling and I can tell you with absolute certainty that a belt is not more efficient than a gear. The old belt drives were however an improvement from the original 6 gear setup and also offered an easy way to get a slipper installed. Once the stealth boxes came out, belt and chain drive went away pretty quickly. I'm shocked to see belts still used in 4wd and onroad. I did love belt drives though! I still have my Bullet Powerglide.Phin wrote:Belts are more efficient than gears but are more expensive and add a little more complexity in design because belts are finicky about getting the tension right.
- 1409 Views
Last post by LaserRC10
- 1319 Views
Last post by bearrickster
- 1997 Views
Last post by blubblood
- 34 Replies
- 3853 Views
Last post by treehugger
- 815 Views
Last post by Marshky
- 1637 Views
Last post by Asso_man!
- 1790 Views
Last post by Mr. ED
- 1452 Views
Last post by rc10johnny
