RC10T parts wreck
JosephS
Has thanked: 1209 times
Been thanked: 611 times
RC10T parts wreck
Post by JosephS »
I saw this RC10t on ebay for a price that seems about right to turn it into parts.
This truck looks like it was a white arm rc10t that was 'upgraded'
Some of the parts were dyed black and that dye is fading and some were painted black. I am hoping to strip the dye from the white parts and use acetone to remove the paint.
I wonder how much will be usable off this truck.
A lot of interesting choices were made on this truck. There are no pins, the arms were installed upside down. The chassis is rough.
morrisey0
Has thanked: 77 times
Been thanked: 1762 times
Re: RC10T parts wreck
Post by morrisey0 »
That makes the rough RC10T I bought today look like new! :D
JosephS
Post by JosephS »
morrisey0 wrote: Thu May 05, 2022 1:47 pm That makes the rough RC10T I bought today look like new! :D
Yeah I was looking for something to focus on. Even just getting it cleaned up and parted out is going to take a bit of effort. I may clean it up and piece it together just to do and a before and after photos.
Has thanked: 2520 times
Been thanked: 2824 times
That reminds me of how my RC10T started out. A lot of work can probably turn that into a decent 10T.
Has thanked: 265 times
Been thanked: 2033 times
That looks like the stuff that I find.
JosephS
Post by JosephS »
Of in person I can see that the pins were replaced with rivets
In person it is in so much worse shape
JosephS
Post by JosephS »
So the outdrives are in much worse condition than I could have imagined
All dissembled
There are a few parts that could use a little buffing.
JosephS
Post by JosephS »
Frankentruck wrote: Thu May 05, 2022 10:36 pm There are a few parts that could use a little buffing.
Yep. I dropped the front shock tower in some acetone before the light completely faded and it came back white. I took a bunch of the nylon and started washing it up. The color is coming off the nylon with just a bit of scrubbing. I think there is a shot for some of the parts to come out of this ok.
This trucks like a sport truck that was equipped with teflon shocks. There was a mix of bushing and bearings in the gear box and it had 1/4" axles.
I am quite amazed at the use of rivets. There was a single pin in the truck all the rest were rivets.
Do you know if the black RPM arms were dyed black or a different material? These arms are showing white in wear areas.
Mark Westerfield
Has thanked: 14 times
Been thanked: 35 times
Post by Mark Westerfield »
Wow, that truck certainly has a lot going on with it.
Been thanked: 498 times
Those arms were available in black and white. Probably other colors too
JosephS
Post by JosephS »
Things are starting to come together.
The chassis is is much better shape that it first appeared.
After some deanodizing it appears nearly all the scratches were light. The tub was also really well cast with nearly no lip.
The front shock tower cleaned up quite nice.
I soaking some of the parts in rit color remover.
Some parts are much lighter in color than before.
Return to “RC10 Truck Forum”
